Thread: Teach the newbie !
    Regular Member David_SRi_2.2DTi's Avatar
    Jun 2007
    Leeds
    Red face Teach the newbie !
    I've been milling around the forums now for a while and have seen several terms which had made me scratch my head and look blank
    Tech2, Canbus, fuel rail?
    ...anyone want to enlighten me
    Leicester
    Tech 2 is the diagnostic tool used by Vauxhall dealers to find faults etc.
    Canbus, this is the digital communitcation used on the car between different systems/ECU's, 99.9% of manufacturers have been using canbus for several years now so it is nothing new.
    Mercedes have started using bluetooth now on prototypes to save on wiring, but not too much success as yet apparently.
    Fuel Rail, this is normally where the injectors are mounted and fed with fuel, they vary in design depending on engine type, for example, 2.2 direct Petrol engines have the injectors mounted directly in the cylinder head and squirt into thecylinder.
    Other designs, like the Astra/Zafira GSi turbo engine have the fuel rail and injectors together but squirt into the inlet manifold.
    Jun 2007
    Leeds
    Quote Originally Posted by Maverick View Post
    ...thank-you Maverick
    The one other question I have been considering asking is what is the difference between the DTI and CDTI engines, I've a 2.2 DTi myself
    Here, there and every where!
    Common Rail is a very high pressure rail that feeds the diesel fuel into the injectors rather than pumped individually.
    Leicester
    Quote Originally Posted by Caterman View Post
    As Caterman has said.
    Full Member Big Sig's Avatar
  1. newbie asking newbie question :-)
    By gavatron in forum Engine & Drivetrain
    Last Post: 6th February 2012, 10:39
  2. teach me.
    By melvyn8181 in forum Diesel Engine related
    Last Post: 25th November 2011, 22:41
  3. Please will some one come and teach me how to use my da and do a proper detail
    By chuckleuk in forum Detailing and Car Care Discussion
    Last Post: 30th May 2011, 15:56
  4. Hi Newbie
    By Wendle in forum Introduce yourself.
    Last Post: 17th October 2009, 10:18
  5. Replies: 35
    Last Post: 9th July 2008, 20:44
