Results 1 to 3 of 3
Thread: Climate Unit
    Washington
    Default Climate Unit
    Does anyone know if its possible to remove the air con unit and replace it with a climate control unit, one for one, in a vec-c? Any mods eg ECU? Thanks
    Regular Member um20's Avatar
    Mar 2007
    Doncaster
    Not easy at all. You'd need the unit, sensors, vent motors, new looms, etc. Your standard AC unit has cables connecting everything up, CC uses motors, so you'd have to take out most of the dash. You'd also most definately need a Tech2 (which, if you'd done everything else, would be the least of your worries!!).
    By all means give it a go and write a tutorial!! Cost you at least £500 I would have thought, probably nearer £1000.
  1. Climate into non climate question
    By SlowCoach in forum Vectra C / Signum Troubleshooting
    Last Post: 19th November 2012, 11:58
  2. For Sale: Climate Control Unit
    By ste w in forum Parts for sale
    Last Post: 5th June 2012, 21:52
  3. climate control unit.
    By mradz in forum Electrical & ICE (including SatNav)
    Last Post: 15th July 2010, 21:08
  4. Help needed on cd70 satnav unit your opinions on the unit please!!
    By maddogwhite27 in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2009, 10:22
