Thread: lowering my vec
    Regular Member Deacon's Avatar
    May 2007
    weston-super-mare
    Cool lowering my vec
    hi i`m looking to lower my car 52 plate sri, i want to go 60mm all round if possible can anyone advise???
    many thanks
    Regular Member Marty J CDTI's Avatar
    Feb 2006
    Yeovil
    Take the wheels off that'll do it. But seriously 60mm, thats a long way down, dropping 45mm puts it jus over the tyres. I'm sure someone will correct me but you might need to roll the arches for 60mm
    SOMERSET
    60mm just take out your shocks and springs and that will give you the same affect. I think 45mm is lower on just springs and standard shocks otherwise you are looking at coilovers, loads of money. (CARLBEAR has done it)
    Jul 2006
    Mexico
    Besides that hudge drop (60 mm) I think it would be a much rougher ride IMO
    Regular Member surreyl31's Avatar
    Feb 2007
    somerset
    60mm u will need coilovers most springs will lower upto 45mm but need bump stops and i belive if u have over 17" rims u might need to roll the arches
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    ive got coilovers (as PIMM said), lowered about 75mm, im on 19's too.
    u might get a bit of scrubin on the front at 60 if u have 235/35 tyres on a wheel with a 35mm offset.
    ive got 225/35 tyres on 8.5" x 19" wheels with 35mm offset, and i got a bit of scrubbin untill i pulled the arches out slightly.
    also u will need to think about the rear camber, im in the process of fittin an aftermarket camber adjuster to the rear as the negative camber is eating the tyres in 3-4 months.
    May 2007
    weston-super-mare
    thank you all very much for your input, think i`ll go 19`s on a 45mm drop.
    sounds safer and easier!!
    but thanks to you all again!!
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Quote Originally Posted by carl bear View Post
    Who cares about these minor things when your car sits as low as it does!!!
    I love it, and wish my car sat that low, not jealous really!
    Jun 2007
    Calne, Wiltshire, UK
    Carl Bear; What Coil overs do you have? and are they a direct fit, or do you have to ****** about with them?
    And those Camber adjusters?
    Where did you get them?
    Cheers.
    Matt
    my coilovers are KW coilovers, they fit straight on.
    and the camber adjusters are form a place in australia called K-Mac.
  1. Lowering on the sri.
    By Roy_Vec in forum Tuning
    Last Post: 13th September 2009, 09:15
  2. Lowering again
    By Ziggy in forum Handling & Braking
    Last Post: 2nd June 2009, 14:19
  3. Lowering
    By euro-dee in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2009, 01:22
  4. Lowering
    By s1nglef1sh in forum Handling & Braking
    Last Post: 6th November 2008, 22:46
  5. lowering???
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2008, 23:49
https:www.vectra-c.comforumshowthread.php28678-lowering-my-vec
