Results 1 to 10 of 11
Thread: squeaking from brakes part 2
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    Default squeaking from brakes part 2
    to cut it short had pads all round fitted 20 july
    took back in yesterday after i was unable to remove locking nuts due to them using a windy gun
    they removed and replace locking nuts and re copper greased all round as i told them about the front passanger side squeaking
    went to great ormond street hospital with girls today and its started again today long periods of time and getting louder
    im thinking this is more than just copper grease again
    anyone have any suggestions what it may be
    1 thing as soon as you tap the brake it stops for a while and then comes back
    Regular Member surreyl31's Avatar
    Feb 2007
    somerset
    i have had the same prob on my 53 plate been in and out of the garage about ten time still cant find the prob. but is ure wose in wet conditions
    Mar 2007
    swindon
    i would say is was worse in wet condition deffo
    im thinking it might be a sticking calipier
    just seems strange that its only happened afted the pads have been re placed
    Mar 2007
    swindon
    mate at work suggested it might be the piston not fully depressing? anyone know if this could be true?
    baz
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    I have the same problem on my 53 plate DTi, a lot of people actually reckon its the backplate rubbing, just bend the back plate out of the way a bit and prolem cured.
    Not tried it on mine yet, but next time the wheels are off, i shall be doing it.
    Mar 2007
    swindon
    Quote Originally Posted by BigMan View Post
    going to sound really thick now but what part is the backplate as im up for trying this at the wekend pics if possiable if anyone can
    anyone else have any suggestion on what i could do at the weekend to solve this
    Mar 2007
    swindon
    little update
    right had it all apart again on sat cleaned the whole calipier area re greased it
    think i found the backplate (back of the disc at the bottom?) seemed ok but gave it a little push back (not much play in it tho)
    went out and after an hour drive it has come back but very very faint but im guessing it will get worse
    so what ever i did had made it a tad better but for how long i dont know
    anyone got any other ideas what it may be
    Mar 2007
    swindon
    just another little update not heard a peep from it since the day i cleaned it all up
    so looks like i cracked it
    anyone else having the same problems take it all aprt and give it all a good clean so it moves freely and have a look at the back plate
    Regular Member nickvectra's Avatar
    shepton mallet
    Hi Baz,
    I'm not an expert at all in mechanic but willing to have a go at it as all the garagist can't seems to solve the problem. But is it that difficult or not? not sure what is the back.....!! any help wpuld be more than welcome please.
    cheers
    nick
    Mar 2007
    swindon
    hi nick im no mechanic by a long shot mate but i always like to have a go it was very easy what i did
    i have a feelin it was the backplate as its started again every now and then so i will be having another look at it soon
    as long as you got the car in the air saft to work with and if your not 100% what your doing get someone to have a look as well
    any tips wanted just ask mate im sure between us we can get it sorted lol
  1. Squeaking noise
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2012, 11:04
  2. Fan motor squeaking
    By philc1210 in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2011, 12:45
  3. squeaking brakes
    By willoftoon in forum Suspension, Wheels & Brakes
    Last Post: 14th June 2009, 15:10
  4. squeaking from brakes
    By baz2003uk in forum Suspension, Wheels & Brakes
    Last Post: 12th August 2007, 23:28
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
