Thread: Question for all painters??
    Regular Member ACE.TAG's Avatar
    Feb 2007
    hamilton
    Default Question for all painters??
    I've got a set of mud flaps and i want to sand down the ruff texture on the surface before i paint them i was wondering what is the best sand paper to use as i was thinking on wet and dry?? Would that be right!!
    Also am i best to use primer first or just paint straight on then laquer??
    Here, there and every where!
    Rub down with wet & dry using finer a grade as you go on then a couple of coats of primer, rub down again with very fine wet & dry. Then paint with several thin coats, then laquer.
    Feb 2007
    hamilton
    Excellent cheers for that mate one last thing do i wet the sandpaper or use it dry?
    It more effective wet m8
    Don't use sandpaper wet though m8 You'll end up with a soggy mess
    Feb 2007
    hamilton
    Cheers mate Ok i'll just wet the wet and dry paper then!
    Mar 2007
    Staffordshire
    Don't forget to use plastic primer first or the paint will eventually peel off.
    Feb 2007
    hamilton
    Cheers for that and i've used plastic primer so i'm safe!!
    I've rubbed them all down and primered them all and i'll be painting them tonight so i'll post piccys up when there done!!
  1. Any good Car painters about
    By Fireyfella in forum General Motoring Chat
    Last Post: 20th December 2011, 16:47
  2. One for you painters and decorators!
    By Vaux-Man-G in forum General Chat
    Last Post: 3rd November 2010, 23:29
  3. any spray painters ?
    By ryanhamil in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2009, 20:22
  4. painters
    By jb-redbull in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2008, 12:59
  5. Any painters on line?
    By blr123 in forum General Chat
    Last Post: 30th July 2008, 22:56
