Thread: Beading around the window frame...
    spoons
    Guest
    Default Beading around the window frame...
    OK, so the VXRD doesnt have double glazed windows (yet..)
    ....but the house does and I've noticed that the rubber sealing bead around the window frame is squashed so flat, that I feel strong draughts and hear the road noise whilst the window is shut !!
    Anyone got any ideas of how I can replace the rubber sealing thingy or any other low cost / low hassle solution. ??
    Cos winter is a comin !!
    Jan 2006
    Skynet HQ EMEC#5
    Low cost option Steve, leave windows shut, put a run of silicon sealer around
    Other than that, don't really know
    Regular Member stusdc's Avatar
    Jan 2006
    AYRSHIRE - SCOTLAND
    Find an industial estate nearby, more than likley you'll find a window manufacturer.
    The rubber bead "should" pull out, manufacturer should have rolls of the stuff, if you ask nicely they'll bung you some, (take a case of beer just in case) worked for me last year.
    Regular Member Scalesy's Avatar
    Oct 2006
    Essex
    Try jamming a piece of card between the opener and the frame if it sticks then seal is fine. if you do need gasket then as stated find a window firm.
    There should be gasket on both frame and casement, no guarantee on your windows?
    southampton
    cheap option could be to get a tin of expanding foam filler and squirt it in the gaps. when its hardened trim it down and sand it
    then put some coats of paint so it matches the rest of the frame
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    I think it just sort of threads in and out, if you can pull a bit out and go to your nearest glass/DIY place, i'm sure you can get some the right size. HTH
    spoons
    Guest
    Brilliant... thanks guys...
    I cut a piece of gasket off the window and took it down to a UPVC Window factory in Walsall.
    They gave me 150 meters of the stuff, and said... "that should do ya !!"
    So I've replaced the seals on the frame and the windows on all upstairs and downstairs on all 12 windows (the ones that open !!).. 72 meters worth !!
    The factory place said they dont use it anymore on the new windows, so its was just sitting around... I gave him £20 for it
    Oh... and its sooooo much quieter now... and no draughts... the windows are like new again...
  1. Sub Frame Question
    By higgy1541 in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2012, 12:26
  2. sub frame tool
    By neill in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2012, 21:05
  3. Zimmer Frame...
    By macdad in forum The 'Off Topic' room
    Last Post: 21st July 2011, 23:21
  4. **FREE** Double Bed frame
    By craigbarlow18 in forum General items for sale
    Last Post: 4th January 2009, 19:00
  5. broken frame
    By parsco in forum Styling
    Last Post: 7th October 2008, 18:37
