Results 1 to 10 of 16
Thread: GSI Vs SXI suspension
    Regular Member Marty J CDTI's Avatar
    Feb 2006
    Yeovil
    Default GSI Vs SXI suspension
    Jus a quick question what is the GSI suspension better than the SXI's? Seen a full set of springs and dampers on Flea bay only covered 8000 miles, jus wondered if it was any better than mine and the price its going at is pennies compared to a new set.
    http://cgi.ebay.co.uk/Vectra-C-3-2-G...QQcmdZViewItem
    Jan 2006
    Skynet HQ EMEC#5
    Is this the same as discussed the other day?
    http://forum.vectra-c.com/showthread.php?t=28446
    Feb 2006
    Yeovil
    Well spotted that man (shrinks into the shadows and hides!)
    Regular Member surreyl31's Avatar
    Feb 2007
    somerset
    how much they up for because u can get lowering springs for £100
    Feb 2006
    Yeovil
    so far £45 all in. But like he said its prob better going for the eibach or similar that are new rather than sticking a used set on.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Plus aren't the GSi's set up is matched to the cars weight? There are many engine variants in the SRi but I'm sure each weight has a set up to match.
    [Ex]Admin Duncan's Avatar
    Yep, you'll need to check what your front axle weight is compared to a GSi - they need to be in the same range otherwise the suspension will be too high/low.
    I can't off the top of my head remember how a 1.9 compares to a GSi for front axle weight. Have a look at your plate inside the drivers B pillar. There will be a few line of numbers - it's the one with 1 - before it.
    Regular Member VectraV6CDTi's Avatar
    Wilts
    I had a 04 plate Vec SXi, just after they started to make them look like the SRi and fit sports suspension. I was under the impression its the same suspension as the SRi/GSi? Only difference I thought was the wheels - SXi are 16's.
    I wouldnt bother spending any money unless you can confirm there is a difference and will see some benefit.
    Quote Originally Posted by VectraV6CDTi View Post
    I believe it's the same as in it lowers it the same amount. But given that the GSi is only a 3.2 engine, and an SRi can be a number of different engines, the weight rating will be different for any SRis with lighter engines - basically what Rushy said.
    Wilts
    So would the suspension on my 3.0 (being the heaviest Vec) be different than a smaller engine? I didnt realise they had different load ratings for different engines.
  1. suspension
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2011, 13:40
  2. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  3. DTi suspension v CDTi suspension
    By jamesy in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 19:02
  4. Replies: 5
    Last Post: 21st March 2010, 12:34
  5. suspension!!
    By leonvectrac in forum Handling & Braking
    Last Post: 11th September 2008, 23:20
