Thread: Travel assistant ??
    Aug 2007
    Plymouth
    Default Travel assistant ??
    http://cgi.ebay.co.uk/Travel-assista...QQcmdZViewItem
    Will this fit my 07 (56) design signum ?
    Cheers, Paul.
    Oct 2006
    Waterloo, Liverpool
    8 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    EBAY advert says the dimensions changed slightly on the facelift : as follows;
    Vauxhall/Opal Travel Assistant
    This is for a Vauxhall signum from 2003/03 to 2005/55 after this date I believe they canged the dimensions by about 2".
    - so I suspect not - sorry
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    I don't believe they changed the dimensions of the TA; if I compare all the pics I've seen here with mine, they are all exactly the same! The only change is -as I understood from other members- that Vx cancelled the fittings as standard but that can be retrofitted for a low cost - ask Maverick about it: he did it on his.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by john_k_sri View Post
    That's twaddle (what the ad says). I know for a fact a pre-facelift TA fits a facelift as I sourced one for Andyvec from someone selling one down here, and it came out of a facelift.
    Nothing in the back seats has changed on a facelift so a TA, as long as it came out of a Signum with the Signum base, will fit any Signum - you'll just need the fitting/wiring kit for your car.
    Oct 2006
    Waterloo, Liverpool
    8 Post(s)
    Trim : SRI NAV XP
    Mileage : 72K
    Makes sense - no point in changing the dimensions of the TA if the dimensions of the car are the same as before.
    Sorry to have got this wrong - just shows you can't take everything you see on Ebay as gospel.
    Aug 2007
    Plymouth
    No worries!! that why i asked........ just trying to get the miss's to go for it.
    Leicester
    It's all the same as stated, go buy it, you'll get it in no worries.
  1. travel assistant
    By chris in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 19:47
  2. Travel Assistant
    By Triple Trouble in forum Parts for sale
    Last Post: 11th July 2007, 08:23
  3. Travel assistant
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2007, 08:42
  4. Travel Assistant or not ??
    By davyboy in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2007, 18:20
