Results 1 to 10 of 16
Thread: Squeaky Brakes
    Aug 2007
    WISBECH
    Talking Squeaky Brakes
    HI ALL ANYBODY KNOWS 2 STOP SQEAKY BRAKES AS JUST CHANGED BRAKES INC DISCS NOW I HAVE SQEAKS
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Copper grease!,as said in other threads slap it on all contact surfaces (except friction face) and the squealing will disappear.
    Aug 2007
    WISBECH
    Question Sqeaky Breaks
    THATS GREAT BUT WERE DO I SLAP IT ON
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Anywhere two metal surfaces meet,caliper to the carrier,pad to caliper spring clip,pad to carrier,the rear of both pads,the slider pins and the large spring clip on the face of the caliper,HTH.
    Regular Member kgsric's Avatar
    Northants
    having same problem with my new brakes, do you have to remove them to put the copper grease in or just slap around?
    cheers
    Jan 2006
    Hornchurch
    pop the wheels off an put some on the
    back of pads
    slide bolts
    an on the runners for pads
    East Midlands
    ?Did you grease the back of the pads when you fitted them ..if not this is the usual cause of brake squeel...do not slap copper grease all over the place..you only need a smiggen at back of pads..you risk contaminating pads if you over use.
    Oh and also some makes of pads are more prone to squeeling than others.
    Jul 2006
    the cheaper, budget pads tend to squeal more then genuine Vx parts. If the squealing's only started since changing brakes, you need to get some copper grease on the backs of the pads.
    In case you didn't realise - brake squeal is caused by high frequency vibration between the metal parts of the pads and the calipers. The grease just damps this vibration and so eliminates the noise
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Some premium brand also squeal due to the hardness of the friction material.
    Copper slip is good, but silver slip is even better with much higher temperature resistance limits, but it's about 10x the price.
    Maida Vale
    Quote Originally Posted by BENNYBED View Post
    " " ?? Why are you pleased that your brakes are squeaky...?
  1. squeaky brakes
    Last Post: 22nd June 2010, 13:19
  2. What causes Squeaky Brakes (Vec-B)
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2009, 09:47
  3. Squeaky Brakes
    By smithi in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2007, 15:03
  4. Squeaky Brakes??
    By Ralph wiggum in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2007, 15:49
  5. Squeaky Brakes
    By tj 666 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2007, 23:18
