Results 1 to 10 of 15
Thread: Tech 2 problems
    Aug 2007
    Shropshire
    confused Tech 2 problems
    Hi all, new to this. I have acquired a tech2 fault code reader. When I plug it into the car ( ignitiop on ) and connect to laptop and try and run the software it says device is not connected.
    However, with the software came a program for VAG-COM. Although it doesn't work for the vx it still recognises it. Any idea what i'm doing wrong?
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    have you got a weblink or picture/description of what your using? unless you get exactly the right lead and software it wont play nice.
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by The converted View Post
    VAG-COM ----------Volkswagen Audi Group ? Wrong software I'd say
    Aug 2007
    Shropshire
    Default Tech2
    Yes I know. The software was on the cd along with the tech2 program. I tried it on the offchance to see if it could detect it and it did but the tech2 software just says the device is not connected.
    maybe I got the settings wrong?
    Thanks for replying.
    John
    Oh by the way, it says its and opel tech2 and I got a new serial to ubs and my laptop likes it. Does all the baud rate and things like that have to match?
    [Ex]Admin Duncan's Avatar
    If you haven't got a Candi interface (CanBus) interface for your lead/hardware then you won't have a chance of reading data onto the laptop.
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Personally, i would leave it well alone. If you have not been trained or know how to use one properly, then steer well clear. It will all end in lots of tears and lots of money!!
    Inverurie
    As stated by John K VAGCOM software is for the VW/Audi group set of cars. I have seen whilst searching the old web software claiming to do the same. Although the general consensus of those in the know on here is that the VX system is very locked down so I have my doubts.
    Search the web and see what you find. Good luck.
    Andy
    Aug 2007
    Shropshire
    Thanks for replies. Its ironic that for the last 6 years I have been driving vw's only to take it for a swim in flood water!! I end up with a vectra with vag software that works and vx that doesn't . How strange life is. Must have been a bad boy in my previous life ( or this one ).
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    i've tried tech 2 from ebay on an old works astra, 1.7dti & it was terrible, i was also using it via a usb serial convertor, ended up sending it back and bought a plug in hand held unit for £30, works a treat, reads the codes and you can delete the codes aswell, it wasnt canbus though but there are plenty of canbus readers on the net that are cheap, i also bought an ecu flasher and remapped the 1.7dti astra, it went a whole lot better then...!!!
    Aug 2007
    Shropshire
    Default Tech2
    That sounds like the same problem. maybe I will do the same as you. Did you get the hand held on ebay ?
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
  5. 3 button key problems (vx tech needed)
    By martinbruce in forum Electrical & ICE (including SatNav)
    Last Post: 24th October 2008, 23:32
