Results 1 to 10 of 13
Thread: 04 Vectra Estate Rattle - Shockers ????
    Feb 2007
    Leeds
    Eek 04 Vectra Estate Rattle - Shockers ????
    Hi all, I have a 04 Vectra Estate 2.0 DTi, it has 54k on the clock and over the past 10k it has developed a rattle when going over bumps or knackered roads and pot holes (most of the time). After reading other threads I jacked it up at the weekend and check springs, wheel nuts, anti-role bars and all looked well check front and rear. Grabbed hold of everything and everything was firm with no noise. If you bounce up and down on the car whilst stood still you don't hear anything. I have had it into the dealer and I told them I thought the shockers were gone but they rekon nothing is wrong and it is fine .. rubbish. All I can think is that it must be the Shockers, I once had an Elise that rattled like hell and replaced the shockers and it was fine.
    Any thoughts folks ??? also where is the cheapest place to get some standard shockers from as I'll change them myself if it is them??
    Cheers.
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Sounds like your Shcoks mate, mine had the exact same symptom's and it was the shocks.
    Try Euro Car Parts for the shocks, Bilstein B4's are good OE replacements and cost about £30 each.
    Regular Member Karl's Avatar
    Sunderland
    My old DTI rattled like hell, shocks and springs cured it. My 1.8 had snapped springs with the same results, rattly as hell on uneven roads.
    Feb 2007
    Leeds
    cheers, guys I'll get some ordered
    Nicking Ya Dinner.
    Don't get Vx shocks, they are not good, go for one of the aftermarket kits like Bilstein etc.
    p.s Vx wouldn't have changed the shocks on warranty anyway, not on an 04 car, you'd be lucky to get new ones out of them on a 6 mth old car.
    Yorkshire
    After the advise you were given did you replace your shocks? Would like to know as having the same same problem and Im really getting sick of it now. Like yourself checked and secured everything else with no joy. Would like know before spending, been a tight yorkshire man and all that!!
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    I had all sorts of noises from one side at the back,thought it might be the upper arm but it was the shock leaking that made me change them and now all the noises are gone.There were supply problems with bilsteins dunno if they've been sorted yet .
    Yorkshire
    Wink
    Thanks for that.
    Had it up on a ramp at the weekend and did not see any leaks.
    Its all a little odd as secured the exhausts in a couple of places with tie straps the other week as when rattling the exhaust it seemed to be the source of the noise. And then for a whole week I could travel without the radio on full blast but then the noise returned. So we put some more tie straps on this weekend but this time the noise remains. Perhaps I will take your advise and sort the shocks, it may be the cause as the roads around here are terrible.
    other VERY well known causes are worn antiroll bar links , worn mounts..and also quite commonly worn void bushes in the upper arms leading to the knocking..
    Dampers would be a good bet if the outer casing is damp or wet..but you can't test the suspension bushes by just wiggling them..preloads on them mean that the best way to check them is when disassembled..
    scotland
    Default roger
    Also have knocking from rear of 2.0dti.
    Just had new shockers but noise still there. Any more ideas?
  1. kyb shockers
    By dcm23251981 in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2012, 12:54
  2. shockers???
    By marshy200 in forum Handling & Braking
    Last Post: 6th January 2012, 21:50
  3. Vectra Estate Voted Top Used Estate in What Car 2010
    By keefy*2010 in forum General Chat
    Last Post: 22nd October 2010, 15:54
  4. rr shockers
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 14:10
  5. Shockers
    By user999998 in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 17:54
