Results 1 to 10 of 30
Thread: Radio Safe???
    Aug 2007
    Gravesend
    confused Radio Safe???
    Bought a Signum about a month ago and the radio is really winding me up!!
    It just keeps making a really loud beep and flashing 'radio safe'
    The sat nav keeps asking for the disk (should it store the info for the sat nav in the memory or do you need to leave the disk in the unit?)
    None of the buttons on the steering wheel work?? is this part of the problem??
    If someone could help you would make my day as the beeping noise is like figernails down a chalkboard and no music when driving is driving me round the bend!!
    Thanks Guys
    Mileage : 000
    Sounds like you might need to put the radio code in, do you have a handbook with the instructions how to put the code in. Also do you have the radio code, it should be in the folder with the handbook on a little card.
    SOMERSET
    You have put up with this for a monthit would drive me mad
    What model unit is it ??
    Aug 2007
    Gravesend
    the modle number is ncdc 2015
    and I do have the radio codde..but I don't know how to enter it???
    thanks guys
    Mileage : 000
    If no one beats me to it I will try and copy it from the handbook and send it to you later.
    Mileage : 000
    Duncan I see you are here can you put the instruction up please.
    STOKE-ON-TRENT
    Hi, don't know if this will work but it's worth a try,
    Switch on the ignition
    Switch off the radio with the OI control
    press and hold the AS control
    Switch on the radio keeping the AS control pressed untill you hear a beep
    the display should show CODE for about 3 seconds
    Then RADIO CODE with the remaining number of attempts ie:----(10)
    enter code with the number controls
    confirm OK by pressing the multi-function control
    SOMERSET
    Quote Originally Posted by madmat34 View Post
    thanks guys
    That is strange because with these headunits there is not a code, it is only able to work when it is tech2 in. i have a 2013 and it does not need a code and does not have one.On your cx car pass it should show radio type/code 2013/xxxx
    Aug 2007
    Gravesend
    What is the AS control??
    It does say radio code on the pass thing'y
    STOKE-ON-TRENT
    If you can't find a AS control button then it's perhaps like PIMM says, it needs to be Tech 2
  1. Ncdc 2013 radio safe
    By jodiexii in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2012, 19:27
  2. Radio gone into safe mode???
    By Rennie in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2012, 15:05
  3. radio safe
    By GSi-Col in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2012, 01:21
  4. car radio in safe mode
    By kayli in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 01:25
  5. Astra radio 7 safe code !
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2008, 23:33
complicated vectra c radio system
