Thread: Oh Noooooooooooo
    Regular Member rayvo-gsi's Avatar
    warrington
    Default Oh Noooooooooooo
    Instrument panel going dead speedo,rev counter,fuel gauge and temp.Indicators work fine but can only hear the ticking no indicator lights.It seems to do this when i have been driving for an hour or so and stays of but like i have read in other threads when you turn the ignition off and then back on everything is fine for a short while and then it goes off again 52plate gsi 3.2 any ideas guys.
    yep, you'll need a new CIM module...dealers job only....
    warrington
    where abouts is this module is it easy to get at.
    Jul 2006
    Mexico
    Not to shure about that CIM GSi ,,,,it could also be just a weak electrical connection on the ABS / ECU as it was in my case....mabe it`s worth to check that before spendig somthing like 300 GBP ( if a recall right)...unless I`m missing something ( which is very common )
    Regular Member Sundance's Avatar
    Scotland
    I agree with bluerob, worth checking the Plug on the ABS connector first, just try disconnecting and reconnecting the multi plug on top of the ABS control unit, if that cures it (although probably only for a while) then you will probably benifit from getting the Modified plug to fit on the control unit.
    Jul 2006
    Mexico
    Quote Originally Posted by Sundance View Post
    I haven`t had any problems for many months now after the plug/replug treatment
  1. Noooooooooooo
    By stehanson in forum Insignia car chat
    Last Post: 18th September 2010, 14:19
