Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Any electricians on here?
    Regular Member danlat1415's Avatar
    Lancashire
    Default Any electricians on here?
    I'm trying to install 2 wall light in my house.
    Couple of questions that need answering...
    1) The closest neutral wire is in another room, and don't want to wreck decorating in there too. Is it possible to use the neutral from a plug socket?
    2) Do I need a new permanent live feed going to the switch, or can I jump the live over from another switch in same socket.
    Also when wiring up 2 wall lights, do they need to be in a loop or in-line?
    (connect to wall socket, then lamp1, then lamp2, then back to wall socket) or (connect to wall socket, then lamp1, then lamp2)?
    I've done electrical wiring in an electrical engineering course at college but it was few years back. Just refreshing my memory...
    On another note, it's not good when a light switch buzzes very slightly when you turn a light on.. what can cause this? It wasn't me by the way, it was already like that, but don't like using that switch.
    Dan
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Hi Dan,
    Quote Originally Posted by danlat1415 View Post
    how come you have live and earth but no neutral, are you taking the feed from a 3 plate light switch? (ie:- live feed, switch wire to existing lights and an earth?)
    Its actually against the wiring regs to "borrow a neutral" from another circuit escpecially so when you are borrowing from power to run lighting, This may also cause you problems with rcd's / rcbo's elcb's etc that keep tripping or it may cause the circuit to not trip out or blow in the event of a fault, neutrals can be the cause of numerous wiring faults. Dont forget to include an earth in the circuit, otherwise it will fail any electrical inspection you may have done in the future.
    Again is it power or lighting..?? (are you taking the feed from a 13A socket or light switch?
    there is no need to wire them as a ring circuit, they would only need to be wired as you say "in line" (radial circuit) Wall lights should be fed from lighting circuits, If you are taking the feeds from wall sockets (13A power sockets) then they wil need to be fused down via a switched fused spur with 3A or 5A fuses.
    A buzzing light switch will normally be loose terminations or it could indicate wear on the contacts, isolate the circuit and re-tighten them all, if its a dimmer switch and it buzzes its more than likely just the loading, but it may also indiacate that it needs replacing aswell.
    Dan
    Hi Dan, I hope i've helped a bit, if you need anymore info let me know, Im an NICEIC Qualified supervisor for a very large testing & inspection company, im a fully qualified approved electrician & I've been doing electrical inspections only for the past 15 years.
    Also you may need to notify your local council planning office, different councils have different policies / criteria that they require notification about.
    http://www.partp.co.uk/consumer/consumer_diy.asp
    http://www.niceicgroup.com/householder
    Lancashire
    Thanks for your reply.
    The wall lights I'm putting in, I'm going to wire up the the mains circuit, and to a 5amp fused switch. It'll be easier.
    How it currently is:
    I have a wall switch (lighting switch) that has: earth, live, and switched live. No neutral. I can't take the neutral from the ceiling rose as I'd have to redecorate again. I don't have access to the junction box or ceiling void, so I was wondering if you could take the neutral from another circuit (mains) but looks like a NO.
    The buzzing light switch is a 2gang switch not dimmer. I'll check the connections next time power is off.
    I know cheap dimmer switches buzz as I've had experience with these.
    for your help, I think it'll be a lot simpilar if I wire up the wall lights to a mains circuit plug socket, and run a 5amp wall switch. Then I don't need to find a lighting circuit neutral.
    I was wondering about the lights being in a loop, or 'in-line' because would the voltage be shared between them if 'in-line' and causing the lights to be dimmer compared to when wired in a loop.
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    Dan, If you are going to run the feed from a socket via a plug top and not a fused spur then may i suggest you put a 3A fuse in it (if a fault were to occur it would blow the plugtop fuse before causing any damage to the 5A switch contacts and / or the switch user and also prevent the lighting circuit in that area also blowing )
    TBH its not the way i would do it but if as you say you want to avoid having to redecorate due to chasing out walls and replastering then you are left with very little choice other than maybe using conduit or trunking, and that's not everybody's cuppa tea when run surface .!!
    You only really need to wire power circuits in rings, the load from a couple of wall lights is not enough to worry about any volt drop causing you problems, well unless they are very far apart...
    Big-pete
    Regular Member SRIFlyer's Avatar
    May 2007
    Colsterworth, Lincs
    Hello DanLat, I am sorry to hi jack your thread but I was about to post to ask for an electricians opinion!! BigPete seems to be quite knowledgeable on it, so I hope no one minds.
    Basically I was putting up some lights in the bathroom and when I took the old light off, I have a pair of red wires, a pair of black wires and a single black wire? I don't know what they are as the wiring on the new light just says, Live, Neutral and Earth. Which one is which? I connected it up earlier and the light came on, but I couldn't turn the ****** off?????
    Not exactly an expert but thought I would have a go and now the wife is mad because I have naffed the new house up!!! Whoops!
    Any help would be appreciated. thanks, Chris
    Regular Member graham a's Avatar
    hull
    looks to me your two blacks are neutral,and your single black is the switch live.the two reds need to be left together in a connector(not connected to anything)
    Regular Member dazzer t's Avatar
    stoke on trent
    Quote Originally Posted by graham a View Post
    just as he says mate, the single black should have a red sleeve or red tape on it to show that is the switch wire, but some electricians tend to double the end over as well.
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    Hi Chris, As mentioned in above replies, Basically connect the single black (which may have a red ID) to the brown on the new light fitting, the 2 black (neutrals) to the blue on the new light fitting and put the 2 reds into a connector block and tape it up, dont touch the 2 reds unless you have isolated that lighting circuit at the fuseboard as these are always live regardless of light switch position unless isolated, and dont forget the earth connection unless its a plastic light fitting, then just put the green / yellow into a connector block
    Big-Pete
    Aug 2007
    Plymouth
    Quote Originally Posted by SRIFlyer View Post
    The most common question / fault in a sparky's life !!
    Regular Member videodoctor's Avatar
    Blackpool
    Part 'p' of the building regulations forbid anyone not fully qualified to undertake any electrical work other than minor ones eg change a socket over.
    These regulations were introduced to protect people and your general lack of electrical theory proves that your not qualified to do your wall lights and it would be an offense to do so.
    You need to employ someone who knows what their doing,preferably a member of the NICEIC or similar.
    Sorry to sound harsh but electricity is lethal and shouldn't be touched by anyone who doesn't know what their doing.
    And yes i am an NICEIC approved electrician.
  1. Do we have any Electricians on the forum
    By Das in forum General Chat
    Last Post: 10th October 2012, 19:01
  2. Any electricians
    By bigmac in forum General Chat
    Last Post: 6th May 2012, 23:27
  3. any electricians on here.
    By Vectra boy in forum The 'Off Topic' room
    Last Post: 13th January 2012, 10:28
  4. Any electricians out there?
    By Harry in forum General Chat
    Last Post: 19th January 2006, 09:36
  5. Any electricians online?
    By 2ltrT in forum General Chat
    Last Post: 10th August 2005, 15:36
