Thread: Door Card Hanging Off-pls Help!
    Regular Member HB39AA's Avatar
    Oct 2006
    GERMANY
    confused Door Card Hanging Off-pls Help!
    I am trying to remove the door trim so that i can get to the last bolt on the door mirror, i have taken out the two bolts on the door handle and popped all the fasteners round the trim, the trim is now held along the top edge - how do i realease this?????
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    i had this problem, you really need to becareful and give it a good tug upwards, i found it easier with the window down
    Oct 2006
    GERMANY
    Quote Originally Posted by 3.2_V6_VXR View Post
    thanks for replying so quick,
    i have tried this but it still does not want to move, is it a case of yanking it straight up? how do those metal clips work that run along the top edge
    SOMERSET
    As said above, hold the door card firmly and lift it straight up and give it a little wiggle side to side and it should go.
    S.Wales, Nr Swansea
    also try putting a flat blade screwdriver underneath to assist you to lift the door card upwards
    Jul 2006
    Mexico
    What I find works a treat is once you've pulled the door card off the retaining plugs and all that is holding it on is the channel on the top of the door - take a small hammer and put the end of the handle inside the door card up against the top of the door card, give it a couple of jabs with the heel of your hand on the hammer head and the card will pop up.
    Hope I explained that well enough.
  1. Behind The Door Card
    By Tam80 in forum Bodywork & Interior
    Last Post: 21st April 2011, 22:02
  2. i need a door card but fixed my door
    Last Post: 11th March 2010, 11:52
  3. door card help
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2009, 19:37
  4. door card
    Last Post: 28th April 2009, 19:00
  5. Door Card Help
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 17:19
