Thread: squeaking from brakes
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    Default squeaking from brakes
    i had my brake pads fitted all round on 20 july 2007 and a few days ago i am getting a squeaking from the front passangers side but as soon as you brake it stops
    its not all the time just a few times each way to work and home somtimes its lastes a few seconds some times is around 30 seconds
    i got the garage to see if the discs was ok also when doing the pads and i was told they was fine so i dont think thats the problem unless they shot away in the past 3 weks
    what could it be as its doing my head right in
    i dont like playing with brakes myself but i know how to strip them down and put back togather so is it worth me having a look or bunging it into the garage to take a look?
    would like to have a look myself tomoorrow (with some helpful tips from the lads on here)as all i have all day is a bbq and a few beers
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    They probably didn't put enough copper grease on the pads,if your happy to do it yourself just coat the rear of the pads (avoid getting any grease on the friction material) and any contact points(caliper to carrier,pad to caliper,etc).If not take it back to the garage and get them to do it properly.
    As above!
    Mar 2007
    swindon
    update......
    then done the locking nutz up with a windy gun and i gone a broke the nut and key ops
    see my other post about it
    http://forum.vectra-c.com/showthread.php?t=28582
  1. squeaking brakes
    By willoftoon in forum Suspension, Wheels & Brakes
    Last Post: 14th June 2009, 15:10
  2. aux belt squeaking.
    By john1 in forum Engine & Drivetrain
    Last Post: 21st April 2009, 20:32
  3. Squeaking from cold
    By Marky in forum Engine & Drivetrain
    Last Post: 15th July 2008, 13:01
  4. squeaking from brakes part 2
    By baz2003uk in forum Suspension, Wheels & Brakes
    Last Post: 29th August 2007, 08:19
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
