Results 1 to 10 of 20
Thread: Auto dimming mirror doesn't seem to work?
    Default Auto dimming mirror doesn't seem to work?
    Hi,
    recently i've noticed that when I get a car behind me (at night) the rear view mirror doesn't dim, causing dazzle.
    anyone else had this problem? Is there a fuse that controls the RVM?
    cheers
    g
    Regular Member Doug-SRidirect's Avatar
    Hemel Hempstead
    Is the indirect night lighting (the orange bulb that shines downwards from the mirror onto the centre console) still working. If that light is working at night (when the engine's running) then I would suggest that the problem's probably in the mirror assembly itself. If the INL isn't working at all, then you may have a fuse blown or some other electrical feed problem.
    Doug
    hmmm. Yeah, just checked it and the IDL seems to function as normal.
    Maybe i'll just mention it next time the car goes in, its still got 9 months of warranty on it.
    cheers,
    g
    Hemel Hempstead
    I can only comment on the automatic gearbox models, but on mine it only dims when the cars going forwards. When it's stationary (in gear or not) or in reverse it's just a normal mirror. So, just shining a torch into the sersor whilst sitting at the roadside won't work. You need to get an assistant to shine a little torch into the sersor whilst your driving.
    If it's faulty, you certainly want to get it done at VX's expense......it can't be a cheap item!
    Doug
    SCOTLAND
    Quote Originally Posted by Doug-SRidirect
    Doug
    was this standard on sri? i have the auto dimming mirror (04 model) but havent seen the orange bulb thing on the mirror.
    Hemel Hempstead
    It came with an option package including the auto-wipers I believe. The indirect night lighting is an orange bulb (flush with) on the bottom of the mirror shining downwards. It has nothing to do with the car lighting switch, it comes on by itself (I suppose it must have a light sersor somewhere). It looks really effective, lighting up the central console, gear selector etc. Makes it all look a bit special (at night!).
    Doug
    my 52 plate sri had both as standard. Then Vauxhall slowly started dropping bits and making them cost options. My elite has them but only cos of the trim package
    Hemel Hempstead
    Andy, What colour's your Vectra? I don't think I've ever seen one in that colour before. BRG or a bit darker? Metallic? Judging by the shine, you spend more than a little bit of time with the turtlewax!
    Doug
    mines an 03 sri and its got the INL and auto dim mirror
    g
    SCOTLAND
    wayhay. never even noticed that before. I thought the light was coming from the info display all this time. Right wheres the hidded coffee maker and ejector seat then
  1. Auto dimming mirror
    By nikroc in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2012, 13:46
  2. auto dimming mirror
    By hairy31 in forum Styling
    Last Post: 19th April 2010, 19:18
  3. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
  4. Auto Dimming Mirror/Auto Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 21:42
