Results 1 to 3 of 3
Thread: Rear Windows.........Again
    Regular Member Damian's Avatar
    Market Drayton
    Default Rear Windows.........Again
    How do I release the glass from the white clasp on the regulator
    Inverurie
    You need to wind the window down so you can get a thin-ish (head no more then 5mm) flat blade screwdriver into a circular plastic push together clip. You need to push it so the shaft goes all the way through (hence the reason why it can't be to thick) and then pull it out again. Tis a bit of a pain but the clip comes apart eventually.
    The clip it's self is made up of two identically parts which push together and lock on each other.
    I don't have a picture to hand, but there is one in TIS.
    Andy
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
  1. rear electeic windows
    By rozzer2006 in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2012, 18:14
  2. Hatchback - Rear Q Windows...
    By Leemarksmith in forum Styling
    Last Post: 4th November 2009, 23:28
  3. REAR electric windows
    By hideyspidey in forum Styling
    Last Post: 11th July 2009, 10:06
  4. rear windows
    By HARRY SRI in forum General Chat
    Last Post: 21st June 2009, 11:00
  5. Trying to do my Rear Electric Windows
    By Damian in forum Bodywork & Interior
    Last Post: 4th August 2007, 02:04
