Thread: Changing rear brakes on estate
    Aug 2007
    High wycombe
    Default Changing rear brakes on estate
    Hi, i have changed brakes on lots of cars but I have an issue with mine.
    a) I cannot get the poiston back in to put the new pads on. I have tried pressing it, turning it so that 'screws' back in. But i cant do it - any ideas.
    b) On the new pads i assume the pad with the special plate goes on the piston side? (the original pads appeared to be modified and dont have that plate.
    Regular Member simac's Avatar
    Wirral
    I think for the rear brakes there is a special caliper re-wind tool you'll need to wind in the piston
    HTH
    Aug 2007
    High wycombe
    Default thanks
    Hi, I thought as much. I tried to use calipers to press it in (eg a modified suspension spring compressor), but it wouldnt do it. And whilst using that you can't swivel the piston.
    Cheers for the swift response
    Andy
    Yep, as above you'll need a rewind tool.
    Re the brake pads - Vx have changed the style of the anti-rattle spring/plate on the rear pads. You got pics of the pads you've got? - easier to then tell you which one goes where. I'm sure I've got some pics of the same pads - will see if I can dig them out.
    trying to do the job anymore without the proper windback tool is not going to do the calipers any good.. too much force on the fine threads means you'll wreck them and have to replace the caliper.. the tool is cheap enough off ebay..£25 iirc..
    Wirral
    Quote Originally Posted by mainand View Post
    Andy
    No probs and good luck !
  1. Help changing brakes over ATM
    By R2XPT in forum Suspension, Wheels & Brakes
    Last Post: 1st July 2011, 13:02
  2. Changing rear brakes tomorrow, any tips?
    By SRI456 in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2010, 23:53
  3. Brakes on 2004 2.2 dti sxi estate?
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2010, 00:33
  4. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
