Thread: Headrest dvd screens
    Aug 2007
    Reading
    Default Headrest dvd screens
    Hi guys, need some info about wiring two headrest screens and a dvd under pass seat. fitted the screen into the headrests and got the wires down inside the seats, now need to get a 12v from battery to the pass seat found the how to so i should be ok, but which gauge wire do i need? Also can this be split to run 2 screens & a dvd or do i need three cables ?Also need a Acc +12v (is this a switch 12v , can i use the rear cig lighter) can this be split to run 3 way switch and dvd (hope this makes sense. cheers Dali1020
    Regular Member pmw123's Avatar
    lancaster
    Default dvd headrest
    hi
    i also have dvd/freeview in my car http://www.showoffyourcar.com/galleries.asp?carid=2734 i used the cigar lighter socket but hard wired from the rear of the console i used the cable supplyed with the units which is smaller than the lighter socket cable.
    ps when wired to the cigar socket it only comes live when car running
    cheers paul
    Aug 2007
    Reading
    Hi pmw123, did you have to run any power direct from the battery to the dvd & screens? Also how did you earth it all. cheers Dali1020
    lancaster
    hi
    all the wiring req is at the cigar lighter point pos and neg
    cheers paul
    Aug 2007
    Reading
    Sorry for being a bit slow with this but the two cables to the cig lighter brown & black one is power from ignition (only on when key is turned on) is the other the earth ?
    lancaster
    yep you have it
    cheers paul
  1. headrest screens what size ?
    By deano1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th November 2011, 16:59
  2. Headrest screens help
    By GAV_SRI in forum Vectra C / Signum Troubleshooting
    Last Post: 4th March 2011, 12:22
  3. Headrest screens
    By McLovinH in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2008, 22:50
  4. Headrest dvd screens
    By dali1020 in forum Electrical & ICE (including SatNav)
    Last Post: 9th August 2007, 20:15
  5. dvd screens in headrest
    By silky in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2007, 20:35
