Results 1 to 10 of 16
Thread: Can you weld Stainless Steel???
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Default Can you weld Stainless Steel???
    I am looking to get a Stainless Steel Tailpipe Trim for my car, as i cannot afford a Full Exhaust System at the moment.
    The one i have found i like is in The States, and it says it needs welding on, but its made out of Stainless Steel(T304 Grade if it helps)
    Can you weld Stainless Steel in the same way you weld normal steel, or is it an entirely different process??
    Full Member Big Sig's Avatar
    It can be welded on, although stainless to mild steel isn't always that good. But yes it can be done with a TIG welder no problem.
    Jun 2007
    Quote Originally Posted by Astrase20 View Post
    Cheers Mate.
    I suppose the other option would be drill a couple of small hole's in it, and put 2 small screws/Nut's Bolts through it to hold it in position.
    Or option 3, wait until i have enough for a Powerflow System....
    Jul 2006
    Mexico
    The ones I just bought are getting weld on Sunday....it`s not the ideal to weld different steals but being just a tip does not worry me that much.
    Maybe after they are soldered I might add some welding glue to play on the safe side
    Jun 2007
    Quote Originally Posted by BlueRob View Post
    Funny enough, it was seeing the pictures of yours that made me look further than England for them, They have a far better variety in America/Canada than we do.
    Jul 2006
    Mexico
    Quote Originally Posted by BigMan77 View Post
    Yeap I found a good selection over US....the difficult part is that most online stores there do not accept foreing credit cards, so the second challenge was to look for an online store with decent tips and that accepted Paypal.
    If you need the web adress from where I bought mine I will gladly post it, actually I think they do ship International orders. I placed the order but make them set it to my mother wich is lives there, then some friends of mine that went there for shopping brougt the box to mexico.
    Jun 2007
    If you have the web address that's be good, Cheers.
    I emailed one company last night, and they replied that it wasnt a problem to ship to England, total cost of the Exhaust Tip and shipping was $50, £25 which is cheaper than i can find one i like over here.
    Regular Member kgsric's Avatar
    Northants
    is the tail pipe the same size as your exhaust pipe? if it is just do a couple of slits down it & put a clamp on it, job done
    Regular Member graham a's Avatar
    hull
    Quote Originally Posted by kgsric View Post
    do you know the sizes big man,then i can check up at work what the shipyard plumbers use when they join high press pipes.the ones i have seen are made from stainless steel with two allen screws and seem to do the job
    Jul 2006
    Mexico
    Here it goes....webstore
    www.autobarn.com
    The company that makes the ones I bought is this...
    www.vibrantperformance.com
    On my 3.2 V6 the end pipes are little more than 2" so I went for the ones that were 2 1/4" on the inlet. I payed around $43 USD for each tail + shiping.
    HTH
  1. stainless steel interior
    By CH-VECTRA-ELITE in forum Styling
    Last Post: 15th November 2011, 22:34
  2. full stainless steel
    By dervdoc in forum Diesel Engine related
    Last Post: 3rd September 2011, 12:57
  3. Stainless Steel Dials
    By redraptor_141 in forum Styling
    Last Post: 18th July 2009, 13:00
  4. stainless steel exhaust
    By samngeorge1985 in forum Styling
    Last Post: 8th May 2009, 14:06
  5. Stainless Steel Exhaust
    By parapaul in forum Diesel Engine related
    Last Post: 12th May 2007, 10:52
