Thread: clutch gone weird
    Regular Member rayvo-gsi's Avatar
    warrington
    Default clutch gone weird
    sometimes the clutch is fine and other times it seems to stick and bite mm's from the floor.And then sticks inches from the top then i have to put my foot under it to lift it back.Any ideas folks car is a gsi 3.2
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    These clutches have no cable as they are hydraulic so it might just need bleeding. Hopefully GSI3.2 might see this thread and give you a pointer on how to do it.
    sounds like either the clutch master cylinder or the slave cylinder inside the bell housing to me.... the only way to tell which one it is , is to clamp the flexible line onto the gearbox.. if it gives a firm pedal then, then the fault lies inside the bellhousing and the gearbox will have to come off..allowing you to check the slave cylinder operation and the clutch pressure plate as well..not a small job at all to do..
    warrington
    Cheers Gsi3.2 you've just made my day
    warrington
    only does this when the car is fully warmed up.Could it just be bad fluid?
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. clutch pedal feels weird
    By abz123 in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 21:05
  4. Weird brake/clutch probs..
    By mark_647 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2011, 17:19
  5. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
