Results 1 to 10 of 22
Thread: How to get the rear springs out?
    Regular Member vectra_andy's Avatar
    Jun 2007
    karlsborg, SWEDEN
    Default How to get the rear springs out?
    got my new spring now. just to put them on. but, yes ther is a but, how do i get the rear spring out?
    it would be nice if someone has pictures to show me.
    Jun 2007
    sunderland
    when a mate done mine on my astra he just pushed the bottom upwards and the popped out( it was up it the air at the time) no special tools needed, dont know if its the same on a veccy tho!!
    Nicking Ya Dinner.
    Quote Originally Posted by hodgey1977 View Post
    That needs doing by someone who knows how, gotta really careful with springs, if one pops at you it could kill you.
    SOMERSET
    The front springs should be the problem
    as for the rear, GSi3.2 done mine in seconds he just jacked the car up and they came out really easy(just pull) but the fronts were much more involved.
    Jun 2007
    karlsborg, SWEDEN
    I know that compressed springs is dangerus. done this many times before. the front is not the problem. thatīs just a mcpherson. itīs the rear thatīs the problem. even if i loosen the antiroll-bar i canīt ge the spring out. ther is one more option. and that is to take out the bult from the lower bushing. but it is very tense. not a funny job to put it togheter again.
    sorrry for my bad english, time to time.
    South Central England
    6 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Just jack one side at a time, so the other side it extended and they should come out. Failing that, you can jack the opposite side, clamp or grip the compressed spring and then swap the jack over to the side you griped and the spring should fall out.
    Jun 2007
    karlsborg, SWEDEN
    yeah, that might work! gonna try that when i´m in the garage next time.
    6 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Sorry, the side you jack will extend and the other compress but you know what I mean.
    Regular Member um20's Avatar
    Mar 2007
    Doncaster
    I've not looked at the rear springs on the veccy but one spring recently cracked (and a bit fell out whilst driving!!) on my corsa. I used the following method:
    1) Chock the front wheels
    2) Loosen wheel nuts on rear wheels
    3) Jack the rear of the car up and support both sides with axle stands
    4) Remove the rear wheels
    5) Support the trailing arm at one end with a jack and remove lower bolt from suspension strut.
    6) Repeat 5) above for other side, supporting it with the standard car jack (to prevent one side being unsupported and putting excess strain on the other)
    7) Lower the trailing arm on one side to the point where the spring will just drop out (watch brake cables do not become excessively strained). Replace with new spring (noting orientation). Jack trailing arm back up and replace lower strut bolt.
    8) Repeat 7) for other side.
    9) Replace wheels
    10) Lower the car
    I had to remove both strut bolts at the same time as on the corsa the arm won't drop enough if the other side is still bolted together. Therefore I undid both so I could lower the other side enough until the spring dropped out.
    That worked like a charm on the Corsa.
    6 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I would not remove the strut bolts if possible as the Vectra is prone to wear there, so best to avoid encouraging it.
  1. kyb rear springs
    By markmac21 in forum Suspension, Wheels & Brakes
    Last Post: 5th July 2012, 14:16
  2. Rear Springs - which ones?
    By Di frost in forum Suspension, Wheels & Brakes
    Last Post: 7th May 2012, 20:55
  3. Rear Springs
    By bobmcn in forum Suspension, Wheels & Brakes
    Last Post: 5th May 2012, 20:43
  4. For Sale: SRI rear springs Ģ10
    By Jow20 in forum Parts for sale
    Last Post: 25th January 2012, 17:57
  5. Rear springs
    By bertbuckie1 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2009, 17:26
