Results 1 to 8 of 8
Thread: Boot Help Kinda Urgent Anybody!!
    Mar 2007
    Hull
    Default Boot Help Kinda Urgent Anybody!!
    Hi, Had a bit of a problem with boot tonight decided it doesnt want to lock at all!! does anybody know the fuse number for the servos or anything relating to the boot which I can look at or take out to sort of reset it? im stuck got a car sat on drive with a boot unlocked! and I can guarantee that the idiots at vauxhall near me wont have a clue! help?!?!?!?!? please the doors all lock so its nothing to do with that seems like theres no power even the lock wont catch?
    help me pleaseeeeee
    rob
    Regular Member Jay Kay 313's Avatar
    Burgess Hill
    sorry matey not got a clue, Hope you get it sortted mate shore some one will have an idea
    Burgess Hill
    oh hang can you take the panal off the in side the boot and then check if there is any power to the locking servo might be a broken wire somewere in the boot???
    http://forum.vectra-c.com/showthread.php?t=20748
    Although it was never clarified if the final suggestion actually did the trick!
    Mar 2007
    Hull
    thanks duncan/all
    ill take a look in morning been laid on boot floor trying to manually lock it by removing the rubber gromet inside the boot but to no avail!
    ill take a look in the light
    thanks
    rob
    Technical directors office
    it'll be a sticky servo catch.....if you remove the boot inner liner you can extract the lock, ( 3 torx bolts hold it into the frame) then undo the 2 torx screws that hold the servo to the carrier..you'll see a threaded cross slide.. WD40 or spray grease that area and the pivot..reassemble..job done..
    for some reason VX run them with minimal lube..a touch of oil and they run a treat..
    Mar 2007
    Hull
    took it to nearby vauxhalls which are getting currently boughtout so they dont want anything to do with the work! been pushed about to other garages and its apparently a failed boot lock!
    cant get hold of one so vauxhall are gonna look at forcing it to lock then getting the part in!
    Regular Member Ian's Avatar
    York
    Sorry - I never updated the thread!!
    Nothing would work on it so we took it to the local dealer and the whole boot mechanism was broken - complete replacement. Apparantley its not uncommon and is a physical failure ie parts have to be replaced.
  1. Lol we kinda know
    By marc vectra sri in forum General Motoring Chat
    Last Post: 24th September 2012, 21:16
  2. What Kinda Oil For My GTI ?
    By Tam80 in forum The 'Off Topic' room
    Last Post: 7th August 2011, 12:34
  3. What Kinda Bulbs ?
    Last Post: 4th August 2011, 21:47
  4. urgent-boot open light not going out
    By andyxedos in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd December 2010, 22:37
  5. kinda new
    By gsxrster in forum Introduce yourself.
    Last Post: 12th October 2007, 13:57
