Page 1 of 20 12311 ... LastLast
Results 1 to 10 of 197
Thread: Signum 2.2 `Direct' - fuel injection pump problem
    Full Member
    Luton
    Unhappy Signum 2.2 `Direct' - fuel injection pump problem
    Facelift 2.2 Signum - Nov 2005. Our problems continue ... after an `engine spanner light' and limp home occurrence, a new fuel pressure regulator and fuel pressure sensor was fitted. Then on test a DIS (coil pack) problem was diagnosed. Having fitted the new DIS pack, the `engine spanner light' has come on again. Now we are waiting for a new high pressure fuel injection pump .... There is a TSB out on this - does anyone have a copy they can post? Thanks.
    Full Member
    Luton
    New high pressure (120 bar) fuel pump fitted - and no flashing lights on the dashboard, so I live in hope .....
    Regular Member VectraV6CDTi's Avatar
    Wilts
    I had a fuel pump go on my old 2.2 Direct 04 plate. I think it was around a year old when it went.
    Bedfordshire
    Quote Originally Posted by omega2498 View Post
    I had my 4th fuel pump, 3rd fuel rail and 2nd fuel tank fitted on my 53 Sig 2.2 Direct last week (and then a new radiator and gearbox when the spanner came up as I drove out of the dealers, but that's another story). The work I had done (fully paid by Vx after 22 months of fuel system failures) listed a Field Remedy FR1614 on the work sheet I've got, but I don't know what that entails.
    Maybe someone here can tell us, enquiring minds want to know.....
    Regular Member Sundance's Avatar
    Scotland
    This isnt the Field Remedy word for word but is the test to check if pump is faulty!!
    (2005.06) - Signum 2003 To 2004 - Engine Type: Z22YH - High Pressure Pump, Fuel Pressure Regulator - Defective (P1191 set)
    Signum/Vectra 2003 To 2005 - Engine Type: Z22YH
    The customer complains that the MIL is on. P1191 us set in the ECU.
    1. High pressure pump defective, vehicle not driveable
    2. Fuel pressure regulator defective, vehicle runs in emergency operating mode
    This is caused by a defective high pressure pump or fuel pressure regulator valve. In case of customer complaint proceed as follows to verify the defective part:
    1. Check fuel feed pressure at high-pressure pump with manometer (engine running)
    Is primary feed pressure less than 3, 4 bar?
    Yes: Low pressure fuel feed failure -> check fuse, relay, intank module.
    2. Measure fuel pressure in the high pressure rail at idle by using Tech2 Datalist.
    Is fuel pressure in the high pressure rail less than 600kPa?
    Yes: High pressure pump defect, replace.
    3. Pull off connector (two-core) of the fuel pressure regulator.
    Measure the voltage of the fuel pressure sensor at 3000RPM (standing vehicle) with Tech2.
    Is Voltage greater than 1, 2V?
    Yes: Fuel pressure regulator defect, replace.
    4. Defect is not clearly allocable to one component. Proceed according to TIS 2000 service instruction.
    TIS Reference Number: E0001614
    bedfordshire
    my high pressure fuel pump was replaced at 54k, 2.2direct 04 model
    May 2007
    Doing stuff
    Mine replaced 29K 2.2 Direct 05Plus a regulator.
    And...........
    yes it stopped running today spanner light will not rev then died, i was in alot of slow moving traffic (nightmare) I spent an hour at the side of the road, tried it and everything OK, got home and it would not run you can crank it still no action. I got a tow to the garage and there are no faults stored and its is running as sweet as. These things are too clever for their own good.
    They are going to replace the regulator again so maybe tomorrow.
    Bedfordshire
    Quote Originally Posted by smithi View Post
    And...........
    Strange, if it's either the pump or regulator there should be a fault code for low fuel pressure showing up.
    May 2007
    Doing stuff
    Yea it is strange I had a problem with an Omega no fault codes that was a crankshaft sensor.
    The garage called and said it had high fuel pressure.
    Bedfordshire
    Have a look here:
    http://forum.vectra-c.com/showthread...184#post424184
    Something new came to light this morning, yesterday my local dealer had 4 Z22YH-engined cars all with the same fault, engine dies after spanner light comes on due to low fuel pressure fault, fault codes stored.
    Interesting eh?
  1. Signum 2.2 direct misfire - fuel pump?
    By jgs1000 in forum Engine & Drivetrain
    Last Post: 4th May 2012, 05:33
  2. vectra 2.2 sri direct fuel pump problem
    By mh99 in forum Engine & Drivetrain
    Last Post: 18th September 2011, 06:51
  3. Options for DTi fuel injection pump failure
    By circushead in forum Engine & Drivetrain
    Last Post: 21st November 2010, 12:00
  4. H.p fuel pump pressure regulator problem 2.2 direct
    By Dobs in forum Engine & Drivetrain
    Last Post: 3rd August 2009, 18:06
  5. Another Signum 2.2 Direct fuel injection pump problem
    By Whoosh in forum Engine & Drivetrain
    Last Post: 6th December 2007, 12:06
troubles with signum 2.2
vauxhall signum fuel pump problems
vectra 2.2 sxi 2004 fueling issue
opel vectra c 2.2 direct problemer
17:24::153: how to solved
vauxhall signum 2.2 direct engine 2004 fue pressure regulator
vectra c 2.2 direct fuel pump
what should the fuel pressure be at the high pressure pump on vauxhall signum 2.2
direct injector z22yh fuel pump repair
p0301 vectra 2.2
vauxhall fuel pressure regulator vectra c z22yh 2.2z22yh p1191z2.2yh fuel low inputvectra 2:2 direct fuek regulatorwhere is the fuel pump on a vectra c 2.2pressure pump injector signum 2.2missfire on recon engine 2.2vectra2004 vauxhall 2.2 direct fuel regulator2004 vauxhall signum 2.2 direct fuel regulator issuesvauxhall 2.2 petrol engine reliabilitywarmstart z22yh p1191fuel pump injection 2.2 petrol vectravectra c 2.2 need diesel pumpvauxhall signum 2.2 direct misfiring problemssignum 04 2.2 direct start problem
