Thread: F on temperature display??
    Regular Member cameraman's Avatar
    Leicester
    Default F on temperature display??
    Sometimes when I switch on the ignition I get an "F" on the radio multi function display where the outside temp normally shows, after a few seconds this goes off & the temp shows as normal.
    Any ideas ?
    f'ing cold???
    EDIT: Sorry couldn't resist. I believe I was the first in!
    Feb 2006
    Dorset
    F**ked
    it means fault , mine does it ofter but works ok after a second or so .
    Jul 2006
    Mexico
    may be...f**ck I don`t know the temp
    Might be worth to check the temp sensor.
    Jul 2006
    A common theme running through this thread....
  1. temperature display
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2012, 13:10
  2. outside temperature display just says F, any ideas ?
    By blackcountryroy in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2010, 17:01
  3. Temperature display stuck
    By johnsav in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 13:02
  4. CD Display - Temperature.
    By aaronfenwick in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2009, 16:14
