Results 1 to 3 of 3
Thread: Tendency to stall
    Aug 2007
    exeter
    Default Tendency to stall
    The problem is as follows. My 1.8 club petrol has developed a tendency to stall. When I slow to a halt and dip the clutch pedal, the revs fall to around 200 rpm, the engine shudders and then usually recovers. It can sometimes however stall completely. It happens with the Air Con/Fans both on and off. It has done 78,000 miles and has been serviced regularly. To address the issue the garage has flushed the fuel pipelines and cleaned the air flow meter.
    Any ideas or suggestions would be gratefully received.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    It may be that the throttle body and idle control valve need cleaning (common problem on the B so I can't see it being any different on the C). There is a how to on VVOC for it if that helps.
    Aug 2007
    exeter
    Thanks, had a quick look and the symptons seems to fit. I am a gash hand car mechanic, so I will have to be careful about this. May just take it to a garage instead!
  1. feels like it's going to stall
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 21st December 2012, 23:36
  2. Anti Stall Feature
    By thegoldenbullet in forum Engine & Drivetrain
    Last Post: 30th July 2012, 21:42
  3. Car wants to stall...?
    By Chunklamb in forum Engine & Drivetrain
    Last Post: 18th July 2012, 20:52
  4. Very lumpy idle and almost stall
    By Netstar in forum Engine & Drivetrain
    Last Post: 28th July 2011, 21:43
  5. anti-stall feature...
    By Harry in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2006, 08:21
