Results 1 to 10 of 26
Thread: twin axle caravan and 2.2 dti saloon?
    Oct 2006
    spalding
    Unhappy twin axle caravan and 2.2 dti saloon?
    bailey ranger 620/6- MTPLM 1540kg, if payload reduced to under 1500kg ,would this be a safe combination? have towed 1325kg single axle `van with no problems but are now considerring an upgrade and hoping not to have to change the car, car`s staying even if caravan has to remain a single axle!!! thanks to anyone who understands all this
    Regular Member Penfold's Avatar
    May 2007
    Sheffield
    the way i understand it is that the gross weight of the caravan should be no more than 80% of the weight of the vehicle towing it
    Full Member Big Sig's Avatar
    according to the VX info 1500KG is the Max limit for a 2.2Dti. So you would be 100% ratio. Someone posted on here a little while ago a site that allowed you to select your can and caravan, it told you if it was ok or not. HTH
    Here, there and every where!
    The safe limit is actually 85% of the gross weight of the towing vehicle providing that the 85% figure is NOT greater than the manufacturers safe towing limit
    http://www.towitall.co.uk/NTTA_law/p.../preparing.htm
    A 1500Kg caravan is too heavy to tow safely with a Vectra.
    Mileage : 000
    What about if it was an estate, mine weighs 2160 kg. that would be ok wouldn,t it, ?
    What your caravan weights 2000+ kg? thats well over the 100%. Max for the V6 manual is 1700 I believe. Who posted up the site where you can input your car and caravan details, it tells you everything you need to know then.....
    Edit, 1800kg for the estate, 2240kg kerb weight for the car.
    Leicester
    Quote Originally Posted by Caterman View Post
    Not true, depends on the Vectra. My caravan weighs 1455kg fully ladenand with a Vectra 1.9 CDTi 150, your towing at 94% of the kerb weight of the car.
    In the ideal world, 85% of the cars kerbweight is the way to go, but according to the caravan club and other reputable sources, you may tow up to 100% of the cars kerbweight providing it is a well balanced outfit.
    The twin axle caravan on this post is too heavy for the 2.2 DTi. You would slog the guts out of it pulling it. A 3.9 V6 CDTi would be the safest bet.
    With my caravan, the tow ration has dropped from 94% with the 1.9 to 81% with the 3.0.
    Quote Originally Posted by Maverick View Post
    I'm not getting into an argument over towing weights Matt, just trying to help a fellow member with info that is available on the web and in the manuals!
    Max braked weight for the 2.2DTi is 1500Kg or so Parkers guide says
    http://www.parkers.co.uk/cars/specs/...px?deriv=22793
    I personally would not want to tow so close to it's limit.
    EDIT: Just found this site http://www.cuddles.abelgratis.net/vauxhall.htm So Parkers is wrong!
    The table has been compiled from Vx OFFICIAL figures. According to this the 85% figure for a 2.2DTi is 1250Kg.
    BTW according to these figures yours should only tow 1410Kg Matt.
    Leicester
    Not getting into a argument buddy, sorry if it came across that way.
    The 3.0 Signum diesel manual max towing weight is 1700kg's.
    The 3.0 Signum diesel Auto is at 1410kg as you have stated, the Vectra 3.0 Diesel estate is a lowely 1200kg's!!!! Even the 1.9 150 auto can tow 1600kg's.
    I think it is down to the 3.0's weak auto gearbox.
    Shrewsbury
    Default 3.0 v6 manual ESTATE
    The greatest trailer weight possible is behind a 3.0v6 estate at 1800kg. TI tow a twin axel 1300kg display unit with mine and so long as you don't look at the instant MPG you are fine. The combination is very stable however a light flashes on the dashboard if it is a bit wet and you take on white van man as you leave a roundabout on a dual carriageway.
  1. Caravan
    By Rob12 in forum General Motoring Chat
    Last Post: 12th November 2014, 01:59
  2. caravan
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2011, 19:15
  3. Replies: 25
    Last Post: 26th February 2011, 20:00
  4. Twin exhaust on a 2.2 (non-direct) Saloon ?
    By Ian-Highlander in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2010, 14:48
  5. vectra estate twin twin exit exhaust
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2008, 12:25
