Thread: Car not well
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Angry Car not well
    Well the car is at the VX garage because of the spanner on the dash just have a call from them it has two faults high pressure fault and something else they were asking question about the K&N filter. I told them that the fault has been on and off since I got the car and the filter was ok.
    So still waiting on them I will try and get the fault codes from them later
    Thanks Steve
    Full Member Jay Kay 313's Avatar
    Burgess Hill
    that's bit of a sod hope you get it sorted mate, The K&N filter should'nt have anything to do with it that's if it's clean
    Astra Estate SRi XP 1.7 CDTi 100
    If they're asking you about the K&N it sounds like the Air Mass Sensor / Meter that's the problem.
    If they try to blame the K&N, tell them that the Air Mass Sensor / Meter is a common fault on the CDTi's and Vx Customer Services know all about it but won't recall the cars.
    Well the garage have just phoned to say they got 34 faults with the car thet have put the car right. I have asked for a print out of all the fault so I can have a look at them but they have said they don't no if I can have them.
    sounds more like 34 registers in the ECU log. It logs all sorts of things, but they're not all necessarily faults. Don't worry dude.
    Jul 2006
    Yep, and it says in black and white on the K&N website and also on the instructions with the filter that it will not affect your vehicle warranty - so I wouldn't worry too much on that front
    Update got the car back all faults have gone so I put the box back on and what did I do put the box on wrong round so the spanner light is back on
    Steve
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Boxes can sometimes produce high common rail pressure fault codes.
    Thanks the spanner goes off when the car is running so should be ok?
    Regular Member Ian's Avatar
    York
    Quote Originally Posted by vectra 120 View Post
    Yep, youve triggered a fault thats now stored in the ECU. The light comes on with the ignition to let you know there was a fault. So long as it disapears after youve started the engine you are fine. It will stop comming on after approx 50 starts or something.
