Results 1 to 10 of 24
Thread: Tyres Wont balance
    Regular Member korlinski's Avatar
    South
    Default Tyres Wont balance
    I have had my tyres balanced 3 times and I still get vibarations in the sheering wheel.
    THe guy said that my wheels took a lot of weight to balance (one side had 115g!)
    We have tried turning the tyres 180 degrees with no joy.
    The company are thinking about ordering a new set of tyres to see if that fixes it.
    I have 17" Ellite wheels with 215/50/17s
    Anyone else found that they wheel needs a lot of weight to balance??
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    When I had my last set of tyres fitted they used a standard balance and the wheels juddered like mad at speed. I went back and they used an Aluminuim balance where weights are added to both the inner and outer edges of the wheel (outer edge stuck on ones inside). The guy said the standard balance is usually fine for ally wheels but he reckons the extra weight of my car was what caused the issue. It probably isn't this but maybe something to think about??
    Dave
    Regular Member Durk's Avatar
    Aug 2007
    N. Ireland
    i had the same problem. It turned out to be the tyres were of a low quality. wot make of tyres have you put on?
    Jul 2006
    Gsi3.2 always suggets having them balanced on 'fine' settings, which means the weights are to the nearest gram, not to the nearest 5 grams.
    Worth a try?
    South
    Quote Originally Posted by Durk View Post
    I have put on Pirelli P7s
    South
    Quote Originally Posted by parapaul View Post
    Worth a try?
    They were balanced to the nearest gram
    South
    Quote Originally Posted by ukanalyst View Post
    Dave
    I have had balancing on front and back on just at the back.
    I agree the inner and outer balancing was better
    Regular Member neil1780's Avatar
    Jun 2007
    dumfries
    i had this too ended up changing tyres and all was well.
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    Quote Originally Posted by neil1780 View Post
    Same here. swapped for 225/45/17's and all is well
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    If the wheels are running true, it is definately **** tyres
    3.2 v6 Signum and loving it
  1. Wii Fit and Balance Board
    By andy13 in forum General items for sale
    Last Post: 16th April 2009, 17:33
  2. Rear Wheel Balance
    By bgm46 in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2009, 22:53
  3. Wheels appear off balance?
    By pauls898 in forum Suspension, Wheels & Brakes
    Last Post: 20th May 2007, 22:14
