Results 1 to 10 of 28
Thread: Limp Mode - 1st offence.
    Regular Member Led's Avatar
    Kings Langley
    Angry Limp Mode - 1st offence.
    OK, I was joining the M25 this morning @ 06:30 and noticed a nice blue '53 Sig infront, put my foot down and 'spanner in car' on dash and loss of power to 2500 rpm, got to a safe pull-in, switch off and wait for 30 seconds - all is fine, drove 60+ miles up the A1, no problems pulling well and rolling along at more than the speed limit
    Comming home this evening - 3 times this happened each time when accellerating - not impressed.
    Yesterday, I put £30 of fuel in at Sainsbury's (Apsley), on the second time this evening I pulled over - lifted the bonnet and checked for the obvious 'hose leaks' but couldn't find anything.
    All help/clues are greatly appreciated. (pics please if possible).
    Regular Member david.aka.judas's Avatar
    Suffolk
    welcome sir - for now you are a true member.............
    Regular Member Silver V's Avatar
    Jul 2006
    mmmmmmmmmmmm
    sounds like a small split in the turbo hose that only makes itself known when the car is warm and you want to put your foot down, as this was the prob I had. VX wouldnt do anything... then the turbo blew up so they had to replace it!!
    Nicking Ya Dinner.
    Hmmmm, supermarket fuel, I'd be inclined to nip in to Shell and add some Vodkatane to it before I went looking for a fault. hth.
    Kings Langley
    Thanks for the replies - I'll carry out a more detailled search tonight.
    I've always used Sainsbury's with a splash of STP cleaner every 4th tank.
    I wouldn't have minded but it's only done 23K and my old Vec B (2.0DTi) has 80K on the clock and not problem (touch wood).
    South Central England
    8 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Get someone else to rev it while you look, you might be able to feel or hear an air leak.
    Kings Langley
    Limp mode again on the way back from the office - applied the right foot to overtake - SPANNER, pulled back in behind the slow car - felt a pr@t.
    Regular Member vcdti's Avatar
    Herts
    Quote Originally Posted by Led View Post
    Last week i had a slight misfire on idle and the spanner came on, drove off on green then foot down and it went off? so the complete opposite! never done it since! im sure they program these cars to frighten you.
    hey "Led" im located very near you
    Kings Langley
    Well, after having a good look around the engine bay and removing the plastic engine cover I still couldn't find anything.
    So I started the engine and nothing audiable
    I rested my hand on the slam bar and my fingers must have touched soemthing and all of a sudden I could hear a sucking sound a good look and a tug hear and there I found this (I've turned it slightly to get a better picture)
    Not sure what it is or what it does, but I've made a temp fix with a vacuum pick-up union from an old Carb. A good test drive (rev's to 4500rpm) in 1, 2, 3 & 4 up the A41 and no hint of the SPANNER.
    Many thanks for the help.
    ps - what is that thingy that the pipe is connected to ?
    Give us a pic a bit further back if you can dude.
  1. Limp mode again
    By craig2.2 in forum Engine & Drivetrain
    Last Post: 5th August 2009, 21:05
  2. limp mode?
    By ryanhamil in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2009, 16:43
  3. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  4. Limp Mode
    By Slippery in forum Engine & Drivetrain
    Last Post: 19th April 2009, 13:22
  5. limp mode
    By vauxvec in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2008, 22:03
