Results 1 to 10 of 11
Thread: 2.0 dti power loss
    liverpool
    Default 2.0 dti power loss
    hi guys,
    i have a lot of faith in this forum, please help just this once more.
    the problem is my vectra 2.0 dti SXI goes into limp mode everytime i go over 70mph. pull over restart the car, and the spanner light goes out. start off again, get to around 80 and it goes into limp mode. as anyone got any idea what it could be. i have noticed a loss in power aswell.
    cheers for looking
    Regular Member Karl's Avatar
    Sunderland
    do you hear a whooshing noise when the turbo kicks in? Can't see why this would be speed related but worth a try (maybe higher load at higher speeds)
    If you do its the turbo hose that has split
    liverpool
    come to think i have'nt noticed a whooshing noise, but when the car is stood idle you can rev the knackers off it and it will rev all the way up and above 5000 rpm and the spanner light won't come on at all. The spaqnner light only comes on when the cars mobile.
    thanks for the reply by the it's very much appreciated.
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    That's the automatic speed limiter.
    liverpool
    is the speed limiter expensive to resolve. Or is it repairable
    liverpool
    would that also explain the loss of power from initial acceleration.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Check your vacuum hoses and MAF sensor - these have been the most common causes I've seen of this kind of problem.
    liverpool
    found the prob. yep you got it. split vacume pipe on the on what looks like a little pump on the front slam panel just to the left of the battery cover.
    put my finger underneath it and it was sucking in air. just rplaced it with some
    rubber piping and some advance and retard piping from the local motor factors.
    oh man thank god for that, i had feeling my wallet was gonna get whole lot lighter down at the local stealers.
    many thanks Juzzy, i'm very happy person tonight.
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    I had exactly the same fault. I was tootling along the M6 then all of a sudden, the spanner light came on and car went into limp mode. I stopped at services, turned off engine for 5 mins and restarted ,all was fine, no spanner light and full power regained. When I got home I found the rubber collar had perished on the vacuum pipe. Dealers stitched me up, cost £4 for a bit of rubber sleeving, but I saved money by identifying the fault with the assistance of the wonderful folks on this forum
    liverpool
    could'nt agree with you more mate. on 3 occasions i have had probs with the car and on all occasions i have been able to rectify the probs with out shelling out a fortine at the stealers. yep so all my best wishes and upmost appreciation goes to these guys on this forum. they are the dogs do dah's.
    keep up the good works guys.
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. loss of power
    By STRETCH2009. in forum Engine & Drivetrain
    Last Post: 8th August 2012, 18:44
  3. Power loss HELP
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 28th July 2012, 12:34
  4. 2L DTI '53 Loss of Power
    By BigTunz in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 17:27
  5. loss of power
    By philly in forum Engine & Drivetrain
    Last Post: 11th May 2009, 07:21
how come my vauxhall vectra 2.0 dti sxi keep on going into limp mode
