Thread: Engine Management Light
    Regular Member skinnyseand's Avatar
    HASTINGS
    Default Engine Management Light
    My engine management light comes on after driving for about half an hour. Each time i reset it the same thing happens. It throttles at the correct rev but the engine vibrates a little awkwardly. The rear O2 sensor and EGR valve have been replaced but the light still comes in. I think I heard mention of the throttle body once but I dont know if it is the sensor attached to it. Does anyone recognize this fault. I desperately need some help. Thanks.
    skinny
    sorry mate, what engine is it?
    HASTINGS
    1.8 Ls
    yep clean the throttle body. Get a can of carb cleaner, remove the main air hose to the TB open the butterfly valve and clean away. Give that a try
    HASTINGS
    thanks. will try that tomorrow.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
