Thread: No sound from back door Tweeters
    May 2006
    scotland
    Default No sound from back door Tweeters
    Hi all, I have just had me car now for 15 months now and this is the first of me realising that I get no sound from the rear tweeters (by the inside door handle). Both sides (rear tweeters) give no sound, the big rear speakers work ok on both sides, the front speakers are all ok. Its a pre-facelift Jan 2005 SRi CDTi 150. Anyone else noticed this on their SRi of similar vintage?
    thanks. Still under warrenty but i would expect the answer from the dealer to go along the lines, the rear tweetres are not fitted to this model mate. So before I phone them, I would like to be armed.
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    got an 05 plate Sri, will go out and check..
    edit: tweeters are tweeting fine mate.
    May 2006
    scotland
    ok thanks
    It may be that they are a 7 speaker system, 4 big speakers (1 for each door), 2 front tweeters, and 1 single centre speaker under windscreen on dash.
    Regular Member ACE.TAG's Avatar
    Feb 2007
    hamilton
    I don't think there are any tweeters in the rear doors of an SRI model unless they've been fitted as aftermarket!!
    Here, there and every where!
    Some do and some don't. Have you checked there are speakers in there m8.
    Feb 2006
    Guttedsville
    The grilles are fitted on all models, but the actual speakers probably aren't there. Easy to retrofit though, once you get the door cards off.
    The fitting of rear tweeters is really hit and miss. Some cars that aren't meant to have them do, those that ought to, don't.
    My old SRi, didn't have them, till I put them in, my new one doesn't list them as standard, lo and behold, they're there!
    Regular Member Damian's Avatar
    Market Drayton
    I concurr having had my door cards off yesterday my 05 SRi doesn't have tweeters either and doesn't have the wiring to connect them up even if it did, until I swapped my door looms for the electric window ones and put in my new switches which have the tweeters built into them
    May 2006
    scotland
    ok guys, thanks. I shall now just put up and shut up. Cannot really be bothered doing anything about it meself, just thought if there was a fault, Vx could fix it for me!!
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Quote Originally Posted by Damian View Post
    The tweeters are built into the switches?? - I don't understand, how are they built into the switches. If I replace the front speakers would I be able to put the tweeters from the front doors into the back doors??
    Quote Originally Posted by Ian S100 View Post
    They aren't! (i don't think ) The LOOM for the rear electric windows has the wiring for the speakers The speakers are behind the grille near the handle (if fitted)
  1. For Sale: Speedo / Door Speakers / Door Tweeters & Boot Lock Mechanism
    By Woody in forum Parts for sale
    Last Post: 21st March 2013, 01:15
  2. rear door tweeters
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2011, 13:20
  3. Rear door tweeters?????
    By stubopvectra in forum Electrical & ICE (including SatNav)
    Last Post: 9th August 2011, 19:45
  4. 2004 3.0 cdti,back door tweeters??
    By Dam3dx in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2011, 22:56
  5. rear door tweeters
    By phil0464 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2009, 22:35
vectra c rear door tweeter speakers connection
vectra c tweeters not working
