Thread: Wheel stays on the ground even when jack is used...Any ideas?
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    Default Wheel stays on the ground even when jack is used...Any ideas?
    Well just finished a home service,as the stealers sent me a letter,but i've 12000 left on the clock before the next service,so i thought time to save some cash.
    The next door neighbour(mechanic) and me sorted an engine flush,oil and filter change(Castrol Sport),fuel filter,new plugs (NGK Platinums) 5.1 dot brake fluid,just as well we bled all round as there was air in the lines(Thanks stealers for the last service!!!!)
    That'll explain the sh!te braking then!
    The weired bit came when bleeding the rears,as we jacked up the rear drivers side wheel it would not lift off the floor,no matter how high we jacked the car
    We had to jack up behind the wheel in the end to get it off the ground.....
    Looking at the shocks and springs there didn't seem to be anything evident,so what do you peeps think?
    Could do with some advice on this one...
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    The shocks MUST be faulty. There is no other reason........or they have detached from the mount. Or the suspension has failed. No other reason
    Apr 2006
    At the Garage
    Ok cheers mate,i take it they wont be covered by warranty then?
    Apr 2006
    At the Garage
    well, any suspension damage that would let the wheel keep sagging down would definatly make itself known before now, so unless the shock isn't attached then i think you can discount that..
    maybe you just needed a bigger jack??..i mean, my 3.5ton garage jack lifts 24" and always clears..but some 'diy' jacks only raise cars about 12" so that could be the problem
    Nicking Ya Dinner.
    Or the ground is subsiding under the weight.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    or you're deforming the area you are jacking on.
  1. Wheel jack collapsed!
    By larrysSRI in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2013, 21:07
  2. Can i ground my amp to the stereo ground?
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2009, 17:07
  3. Wheel ideas (again) lol...
    By danBoy in forum Styling
    Last Post: 15th March 2008, 16:37
  4. Wheel Jack Trouble
    By jontymo in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2007, 16:47
