Thread: How do I remove the heater console facia on a 05' Zafira A
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Default How do I remove the heater console facia on a 05' Zafira A
    Just wondered if any one here knows how to do this. I don't want to force it off to find there are screws somnewhere. The reason is I have a hands free bracket out the side of it I need to change the wiring for a new car kit.
    The panel is the one that the heater controls are on.
    Regular Member Inspektor's Avatar
    Northampton (Santa pod)
    Best bet if no one on here can answer is try Astra owners clubhttp://www.astraownersclub.com/vb/ used to astra-sport.co.uk.
    A good friendly bunch. They have a Zafira forum and a how to forum.
    HTH
    Regular Member Ben H's Avatar
    Herts\Beds Border
    If it's the new shape the heater control has 4 metal clips one in each corner. It's easiest to remove the head unit first, then you can pop the top two then pull it to release the bottom two.
    Once out undo the screws and you can route your cable nicely in behind the trim.
    Herts\Beds Border
    Oh just reread it's a Zaf A. In that case I think you force the ashtray downwards and it pops out. You'll then find two screws behind, undo these and you can pull it out from the bottom enough to locate your bracket, if it's a dash mount with a big double sided sticky pad be warned, they are **** to put it blunt.
    Again you can also route your cable in behind the trim once released.
  1. How do you remove the centre console?
    By lee gsi in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2010, 19:04
  2. Zafira Heater/blower motor
    By glenboy in forum General Chat
    Last Post: 9th June 2010, 22:01
  3. How do I remove the PCB from a CD70 facia???
    By luke4487 in forum Bodywork & Interior
    Last Post: 16th May 2010, 12:17
  4. how do i remove centre console
    By Alanrim in forum Bodywork & Interior
    Last Post: 26th July 2007, 09:52
  5. How to remove Vectra C Centre Armrest console?
    By cjchan01 in forum Bodywork & Interior
    Last Post: 14th April 2007, 14:05
