Results 1 to 10 of 13
Thread: engine issues
    Regular Member chinky's Avatar
    midlands
    Default engine issues
    ive a vect 56 1.9cdti 120 problem is that at least once a week the engine seems to juddder a bit like its misfiring this is only aparant on tick over and the car drives fine untill at idle if i switch engine off i get a nasty burning smell (only when the juddering as happened) and then i restart and all is fine. any ideas
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i had a small problem like this, a flat spot sort of thing...got a new EGR valve fitted the other day and now seem's ok
    Midlands Mod Shop - NFFC.
    Full Member Jay Kay 313's Avatar
    Burgess Hill
    This may sound silly but have you got your Air con switch on as ive found with mine ok it's the 150 1.9 but mine judders when the A/C compressor kick's in and out but when it's switch off run's fine just a thought
    Astra Estate SRi XP 1.7 CDTi 100
    midlands
    nope aircon makes no diff its like the timing is out or somthing tho if i switch off then all is fine so it isnt timing either
    Burgess Hill
    How long have you had the car??
    midlands
    since new in october
    Burgess Hill
    Should be still under warranty could be as DitchP say's the EGR valve or I know some peep's have had problem's with injector's. Take it back to the stealer's and get it plugged in to Tech 2
    midlands
    yep is due a service soon and i can live with it till then just wondered if others had this prob
    Feb 2006
    Dorset
    mine does it at tickover , you can feel and hear it shudder , only on tick over though ,
    Burgess Hill
    Quote Originally Posted by chinky View Post
    That's what we are here for
  1. V6 CDTI engine issues
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2012, 10:18
  2. I need to clean my engine/bay without electrical issues.How?.
    By felixx in forum Detailing and Car Care Discussion
    Last Post: 19th July 2010, 08:40
  3. 1.8 VVT Engine Issues!!!
    By SteB13 in forum Engine & Drivetrain
    Last Post: 7th June 2010, 17:39
  4. Engine Issues? 1.9 CDTi
    By Ean in forum Engine & Drivetrain
    Last Post: 14th April 2009, 19:25
  5. Cruise control and engine temp issues
    By zerocool in forum Engine & Drivetrain
    Last Post: 3rd February 2009, 02:01
