Thread: Trying to do my Rear Electric Windows
    Regular Member Damian's Avatar
    Market Drayton
    Default Trying to do my Rear Electric Windows
    Am trying to do my rear electric windows.
    I have installed the looms and all appears to work, the little speaker works by the switch so I presume the loom works fine, however ...........
    As my regs came from a scrappy one of them is in the open position and one is in the closed position. With no power to the rear doors for the windows until activated by TECH2 how on earth do I go about installing them.
    I can't seem to shift them by hand at all ???
    Hope someone can help as I have some very bare doors and don't want to drill my old ones off until I know for sure how to do it
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    How about connecting to a battery direct,just mind your fingers!
    Market Drayton
    Wouldn't know which pins to connect it to as there are 6 !!!
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Is the control unit mounted to the motor?,if so you'll need to look at a wiring diagram or someone else's car to work out the pins.
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    can't remember at the moment but you need an earth and two lives to move the motors (one perminant and the other the switching)I did this using a battery and made up a mini loom with terminals from an old radio loom,would have to have a look in the door for you to find the wires but you only need the three to move them
    will have a look maybe later today for you mate (got a lot on today!!)
  1. Electric Rear Windows?
    By JDX-SRI in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2011, 00:38
  2. REAR electric windows
    By hideyspidey in forum Styling
    Last Post: 11th July 2009, 10:06
  3. electric rear windows
    By kenp in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2008, 10:01
  4. rear electric windows
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2007, 21:04
