Results 1 to 10 of 13
Thread: Help! Can't get in the car!!
    Regular Member danlat1415's Avatar
    Lancashire
    Default Help! Can't get in the car!!
    I think my key battery was going - it opened after being pressed a few times. So I changed it. only took a couple of seconds.
    Now my car won't open!!
    I can open it using the key, but that will set alarm off and can't turn it off with key, so don't want to do that.
    Whats happened?
    How can i get it fixed without the use of my car?
    Open the car manually with the key, the alarm will go off, stick the key in the ignition and turn on, the alarm will go off.
    Lancashire
    I hope you're right.... 1 minute.
    spoons
    Guest
    lol
    Lancashire
    You're a star.
    It worked.
    Plus, now the remote is working too.
    Hmmm weird.
    I've only got 1 key too, so may have to tell the other half I need the new flip key
    Regular Member R-man's Avatar
    Beds
    All hail vectra-c.com!
    Quote Originally Posted by danlat1415 View Post
    You're a star.
    It worked.
    - ya didn't believe me that it was going to work did ya?!
    Yep, it will have resynchronized itself to the car when you put it in the ignition.
    spoons
    Guest
    - I hope your right.....
    We're not here to be wrong
    for anyone else reading this. If you key doesn't re-sync itself after this procedure do the following -
    Unlock the car with the key in the door.
    Place key in ignition, turn to position one on th eignition barrel.
    Lock the car with the key in the ignition.
    All should be re-sync'd.
    HTH
    Lancashire
    Quote Originally Posted by spoons View Post
    Thats true, don't think the advise on here has been wrong yet. No need for tech support, or haynes manual
