had battery of car today and the one touch window close on the drivers side dont work now, got to hold the button all the time.
is there a trick to turn this back on??
Yep.
Press and hold the button in the up position for three seconds when the window is closed, need the ignition on, can't remember if there's a beep or something, but basically it re-learns its function.
Last edited by AndrewTi; 3rd August 2007 at 00:15. Reason: more detailed description
No not usually a beep, just have to keep it held for a few seconds longer after it reaches the top.
Yep, all the way up and keep holding the button until you hear the motor stop, all the way down and do the same. it needs to learn the limits.
How can a window learn it`s limits?
And I don`t?
because its electronic and your not!
thanks sorted and working now
