Thread: one touch window faulty?
    Regular Member jonnye's Avatar
    Feb 2006
    Derby
    Default one touch window faulty?
    had battery of car today and the one touch window close on the drivers side dont work now, got to hold the button all the time.
    is there a trick to turn this back on??
    Feb 2006
    Guttedsville
    Yep.
    Press and hold the button in the up position for three seconds when the window is closed, need the ignition on, can't remember if there's a beep or something, but basically it re-learns its function.
    Last edited by AndrewTi; 3rd August 2007 at 00:15. Reason: more detailed description
    Regular Member Ben H's Avatar
    Herts\Beds Border
    No not usually a beep, just have to keep it held for a few seconds longer after it reaches the top.
    Full Member Big Sig's Avatar
    Yep, all the way up and keep holding the button until you hear the motor stop, all the way down and do the same. it needs to learn the limits.
    Jul 2006
    Mexico
    How can a window learn it`s limits?
    And I don`t?
    because its electronic and your not!
    Feb 2006
    Derby
    thanks sorted and working now
    Regular Member dazzer t's Avatar
    stoke on trent
    Quote Originally Posted by Astrase20 View Post
    how do you know bluerob could be a cyborg from the fourth dimension...
    Jul 2006
    Mexico
    Quote Originally Posted by dazzer t View Post
    shhhhhhhh don`t tell any one mate....that only between us oh....and I am from the fift not fourth dimension.....biiiiigg difference!
  1. Electric window one-touch issue!!
    By Tyger in forum Bodywork & Interior
    Last Post: 9th February 2011, 20:18
  2. Faulty power window switches
    By bax in forum Electrical & ICE (including SatNav)
    Last Post: 31st March 2010, 10:00
  3. lost one touch window close after clutch fitted
    By mat osborn in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2008, 17:18
