Thread: Wheel alignment
    Larkhall
    Default Wheel alignment
    I have noticed excess wear on the front passenger side tyre. The rest have a lot of tread left on the outside and this tyre only seems to be wearing on the egde rather than anywhere else. Is this to do with the alignment of the wheel?
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    classic, wheel alignment problem
    The symptons of a car out of alignment are:
    • Uneven or rapid tire wear
    • Pulling or drifting away from a straight line
    • Wandering on a straight level road
    • Spokes of the steering wheel off to one side while driving on a straight and level road,
    • If the tread is deeper on one side than the other, have your wheel alignment checked
    says it all.................
    usually happens when you kerb the car, bump up kerbs or drop into a pothole.
    Full Member Big Sig's Avatar
    Is it wearing on the outside edge? Maybe slow down round those round a bouts!
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Most likely - get the old tracking reset
    It's normally the passenger side that goes out because thats the wheel that hits the kerb the most when the misses is trying to park
    Larkhall
    I'm always parked up on a grass verge, with the passenger side tyre bumping up on the edge of the kerb.........
    Regular Member korlinski's Avatar
    South
    Quote Originally Posted by tamf2007 View Post
    Try turning you wheel full lock before mounting the kerb. This will mean the wheel with roll up the kerb and get less lateral shock.
    Also mount the kerb slower. This will help to
    Jun 2007
    in a white box
    don't do it at 30mph..................slow down first...........
    whilst your down there, have a feel of your tyre sidewall for any bulges. tyre side walls are only one or two ply and can bulge when you drive up the kerb..... saves a blow out........
  1. 4 wheel alignment
    By tangoman in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2012, 21:42
  2. wheel alignment
    By matt2005 in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2012, 12:32
  3. 4 Wheel Alignment
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2011, 20:06
  4. 4 wheel alignment
    By dave_taiho in forum Northern Ireland (RO - Vacant)
    Last Post: 9th March 2010, 16:35
  5. Wheel Alignment?
    By parapaul in forum Suspension, Wheels & Brakes
    Last Post: 23rd November 2008, 23:09
