Thread: Rear bumper loose?
    May 2007
    north wales
    Default Rear bumper loose?
    As Summer has finally arrived,I've been driving with the window down,and occasionally notice a "plasticky" rattle at low speed.Decided to check it out,so had a butchers under the car,and was surprised to notice that if I grab the plastic "skirt" under the rear number plate,it moves in and out about 1/2" to 1".It seems pretty firm at the sides but not so good in the middle.It looks like it's only held by two clips that slot into the bumper.Can't see where the bumper is fixed to,cause this is moving in and out with the skirt.Checked my neighbours Fiat and his is rock solid!Is it just a Vauxhall thing or am I missing some fixings? It a 52 plate 1.8 Elegance.
    Any help much appreciated,
    Pete.
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    Just checked on my 03 Elite and mine seems pretty rigid, hardly any play at all. Didnt check underneath though so dont know how its held on.
    May 2007
    north wales
    Thanks for checking.Looks like I'll be under the car this weekend then!
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    You're not alone - Both SRi's i've had have suffered from this,if you tap the bumper by the numberplate it rattles against the metal crash bar thats behind the bumper
    Found that the two large clips never stay in the bumper on their own so on both cars i hot glued them them in place and that seemed to do the trick
    May 2007
    north wales
    Cheers Stig,Can't believe that Vauxhall thought that two plastic clips is enough to secure it!Then again after seeing my Stepsons plastic to metal gear linkage on his Corsa.maybe they did!Might try your fix.Thanks.
    Kingston
    gotta loe the vx saving money methods!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i have the same probablem m8, there ar to plastic bars that fix to the bumper and some where under the boot/bumper bar???
  1. My bumper loose on the front corner
    By Mark2.2 in forum Bodywork & Interior
    Last Post: 21st July 2009, 10:34
  2. Loose/Wobbly Signum Rear Bumper
    By snapsnap in forum Bodywork & Interior
    Last Post: 9th April 2009, 15:35
  3. Loose rear end...WHY?
    By BlueRob in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2008, 19:15
  4. Loose rear end...WHY?
    Last Post: 29th July 2008, 18:33
  5. loose front bumper
    By stevietiger in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2007, 18:50
