Thread: lowering kit?
    Regular Member coylo5's Avatar
    May 2007
    n.ireland
    Default lowering kit?
    can anyone recommend a lowering kit for my 07 1.8 h/b.
    Jul 2006
    Depends how low you want and how much you have to spend...
    A set of Eibach springs from LMF will set you back about £130 and drop the car by 35mm, or you can look at uprated shocks too...Bilstein shocks and PI springs have been used quite successfully.
    The Vec C has been about for a bit so have a look round the internet and see what you can find.
    HTH
    Regular Member Matt21385's Avatar
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Koni FSD's & springs are a good option. Spikey & myself both have this setup
    May 2007
    n.ireland
    how low has it been lowered any pics?
    i probably want a 35 or 40mm drop, i dont want it that low that half the wheel is lost behind the arches.
    May 2007
    n.ireland
    can someone post a link coz i cant find any for a 07.
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    The pre-facelift suspension kits should fit the facelift vectra also. Just make sure its the correct axel weight for your model. Im sure I will be corrected if this isnt the case.
    May 2007
    n.ireland
    i think im gonna go with pi springs with my standard shocks for now, and drop it 40mm.
    is it a job i could do myself ?
    if you have the correct tools then yes.... there's a written guide on here somewhere as to how to do it..but with all the kit it takes around an hour to do the lot..
    Regular Member surreyl31's Avatar
    Feb 2007
    somerset
    look at G MAX springs as well i had them on a rover and my mates got them on his astra we both found them to be very good
    May 2007
    n.ireland
    aye i bought gmax springs earlier £80 brand new.
  1. Lowering on the sri.
    By Roy_Vec in forum Tuning
    Last Post: 13th September 2009, 09:15
  2. Lowering again
    By Ziggy in forum Handling & Braking
    Last Post: 2nd June 2009, 14:19
  3. Lowering
    By euro-dee in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2009, 01:22
  4. Lowering
    By s1nglef1sh in forum Handling & Braking
    Last Post: 6th November 2008, 22:46
  5. lowering???
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2008, 23:49
