Results 1 to 10 of 21
Thread: AFL recall?
    Regular Member gizmo10119's Avatar
    Cambridgeshire
    Default AFL recall?
    Hi
    I had mentioned a few weeks ago that i was selling my vec, luckily i have managed to avoid it now! (now ive sold all the goodies i had collected for it!)
    I have had a few problems with the car in the past and it has now developed a few more faults so i have booked it in at the dealers.
    Whilst talking to the service dude describing my faults:
    knocking coming from thr front (well more of a twang really lol)
    drivers side headlight condensation
    drivers side front indicator sometimes works
    he also mentioned that my car needs to come back for 3 recalls, now i had a letter regarding the heated washer nozzles a few months back, i called to book it in and was told that mine did not have them so there was no need to worry! i have now had another letter reminding me to get them checked, this time the guys say it does need to havethem reworked?
    also it is being recalled for the diesel particle filter and the AFL Xenon system?
    anyone experienced this or know what its about??
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    I have had the recall on the heated washers
    I don't have DPF but this recall on the AFL is it on all car or just f/lift models
    Cambridgeshire
    im not sure wether its just facelift or not, from what the guy was aying its a fairly new one he had not come across before
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    I have a facelift with AFL, I haven't had a recall? I think the heated washer jet one only applied to the pre-facelift.
    Postal strike could have delayed my notice. When did you get the recall notice?
    Paul.
    Cambridgeshire
    i only had a postal recall for the washer jets, found out about the others this morning from the dealers
    the DPF recall involves either just changing the software for it, or replaceing it as well as the update..we had that done on the family 1.9 about 6 months ago as part of the investigations into the cars poor running..
    The heated washer jet recall is just so they can disable the element ( they catch fire).. Haven't heard of the AFL recall yet thou..
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Oh well, mine is due a service in a couple of months, suppose i'll find out then.
    Cambridgeshire
    Mark, would the DPF affect fuel economy?
    i dont know if its just me but im sure it uses more fuel than it used to!
    i havent bought heavier shoes or anything like that but i havent measured or calculated to see if its different
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    [quote=gizmo10119;341022] would the DPF affect fuel economy? /quote]
    Yes in a short answer. If the car was doing 40mpg, as the DPF comes in it will cut in that in half. On my V6 when the DPF is running and I am doing 65 in 6th on the motorway then mpg is cut to around 22mpg. When the DPF has finished it's then back up to 40ish.
    Regeneration at that speed can last for anywhere between 8 and 20 miles depending on how much needs to be burnt off. The DPF needs to heat up to 700C and to do this it increases the fuel to acheive the desired temp. The user should not notice when the DPF comes on.
    Mine has just had an ECU update reversed as the DPF was causing some poor running. now it seems ok. Only the 1.9 was on the recall list for the DPF.
    Administrator plasma's Avatar
    On the Forum
    574 Post(s)
    Engine : 150
    Mileage : 74000
    I'll go into Vx tomorrow on the way home and find out the deal with the AFL / Xenon lighting... and if they have my heated nozzle rewiring kit in yet :/
  1. BMW Recall!!!!!
    By Das in forum Comedy & Humour
    Last Post: 10th December 2012, 05:56
  2. Recall
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2011, 21:30
  3. Recall ??
    By silverhairedracer in forum Insignia car chat
    Last Post: 27th November 2009, 19:10
  4. was there a recall on dpf
    By iasha in forum Engine & Drivetrain
    Last Post: 23rd November 2009, 14:22
  5. AFL recall?
    By janc in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2008, 17:48
