Results 1 to 10 of 19
Thread: Clicking noise only when turning ignition
    Regular Member mbonnick's Avatar
    Jul 2006
    letchworth, hertfordshire
    Unhappy Clicking noise only when turning ignition
    For the last 2 mornings when I turn the ignition I just get a clicking noise that sounds like its coming from the glovebox. The car does not try to turn over and hence will not start. I tried it yesterday evening and this evening and it starts first time and every time I try it after that. Not that it is particularly cold in the mornings but obviously it is colder than in the evenings so is it something to do with the outside temperature??
    I dont believe the battery is at fault as tonight I loaded the system ie lights and mainbeam on, fan full on, aircon on and it turns over no problem and starts straight away.
    It is a 2002 2.2 Elegance and apart from this it runs like a dream. Has anyone else experienced a similar problem or does anyone have any ideas how to sort it or even whats causing it???
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Main Relay would be my guess if they still have them..
    Jul 2006
    how can i check?
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Hey, a local guy.
    Ours was playing about lately when it would not run when cold, it just kept stalling after 10 seconds. Everytime it stalled if you tried starting it again within 10 seconds or so you'd get the clicking from behind the glovebox. It was almost like part of the car was wanting to start but the management was preventing anything else from happening.
    Post on my problem are http://www.vectra-c.com/forum/showth...ght=fault+code
    and
    http://www.vectra-c.com/forum/showth...light=stalling
    Nov 2005
    Somewhere in time
    Quote Originally Posted by mbonnick View Post
    how can i check?
    Have a gander in the fuse/relay box which is next to the battery - not sure which colour the main relay is but i know when i had one fail on a vec b it got very hot....
    Feb 2006
    Dorset
    there is a fusebox at the end of the dash passengers side and if you take the glovebox out i think there are some relays in the rear of that same fuse box . i could be wrong , if in doubt give it a clout.....
    Melbourne, Australia
    Could be an immobiliser problem - does a padlock symbol display on the instrument cluster when the car fails to crank?
    Mar 2007
    south wales
    THE NOISE IS THE RELAY QUITE COMMON TO ABLE TO HEAR THEM SIMILAR ON OTHER CAR TYPES eg RENAULTS.
    hit caps lock for us Andrew..
    Mar 2007
    south wales
    Is that better..
  1. Clicking noise when turning the heater dial
    By AntSSSS in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2013, 20:33
  2. 3.2 V6 Clicking on ignition turn.
    By arfurd in forum Troubleshooting
    Last Post: 1st November 2012, 16:16
  3. beebs when turning ignition off
    By NPS in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2011, 07:32
  4. Noise when Turning Ign Key
    By Redviper in forum Troubleshooting
    Last Post: 3rd February 2011, 14:00
  5. Vectra 3.2 05 Gsi clicking noise when ignition turned on/off
    By bignew in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2009, 19:36
vauxhall zafira wont start just clicks
Clicking noise on vectra c when turn the key
vauxhall vectra clicking noise
vauxhall vectra c wont start just clicks
vauxhall vectra wont start clicking noise
vauxhall astra click on ignition
vauxhall vectra wont start just clicks
vectra not starting clicking
vauxhall corsa clicking noise when ignitions on
zafira ticking on ignition
vauxhall vectra make a clicking noise when ignition is turned on from passengers side
ignition not coming on opel signum
corsa c 1.2 popping noise when ignition turned on
Vauxhall combo just clicks when I turn the key
vauxhall combo ignition clicking
vectra b relay click
vauxhall astra blower relay clicking ignition not starting
corsa b ignition clicking noise
vectra clicking but not starting
opel astra ignition key turns no click sounds
meriva marks noise when turned on the ignition
1.2 corsa clicking ignition
vectra 3.2 popping.noise
constant clicking on turnover from vauxhall signum
opel signum 3.2 v6 clicking
