Thread: changing front rotors
    Australia
    Default changing front rotors
    i have been through the 'how 2's" section and have only come across pad change. i will be changing my rotors this weekend and was wondering if there was a how to on it of i'll go into discovery mode and figure it out? or if any1 can give me a simple run down on it that would be good.
    cheers.
    matt from downunder
    Rotors as in brake disk?
    it's easy really..just remove the caliper and pads as per the how-2..
    then undo the caliper carriers 2 mounting bolts at the rear of the disc ( rotor) and remove the carrier.. then just undo and remove the 1 mounting screw on the face of the disc hub..the disc will now knock off.. either easily or brutally dependant on how long they have been fitted to the car..
    Now the IMPORTANT BIT....spens at least 5 mins sandpapering the newly exposed hub flange to get rid of all traces of rust.. any rust left will make the disc sit wrongly and will lead to problems later.... after sanding, clean off the new discs with solvent cleaner ( carb cleaner etc) and then remount, secure with fixing screw..
    Clean out the threads on the carrier mounting bolts and refit with some studlock/threadlock to secure them in place.. reassemble the calpier and new pads as per the how-2.. get in car and gentle press the brake pedal to bring the new pads up to the disc before driving the car off..then just try and brake gently for the first 50 miles to give the pads time to settle in....
    Ahh there it is! beaten again!
    Quote Originally Posted by Astrase20 View Post
    oh yes.... the fast service dept is online..
    Australia
    thx for the fast response. muchly appreciated. just 1 question. y is it that you clean of the disc, does it have a coating???
    job sounds easier than i though it would be. thx again
    Quote Originally Posted by 10PEL View Post
    Yes, they have a thin coating of oil stuff to stop them rusting when they are sat in storage. Very important to clean it all off or your stopping distance will be somewhat increased!!
  1. DBA 5000 Street Series rotors.
    By Vectra_C_Chris in forum Handling & Braking
    Last Post: 27th May 2011, 20:28
  2. Replacing Discs/Rotors to Pads Ratio ?
    By 67688c in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2010, 07:31
  3. changing bulbs on front
    By astratovectra in forum Bodywork & Interior
    Last Post: 9th March 2008, 21:07
  4. Help!!!!!!!! (brakes/rotors)
    By 10PEL in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2007, 23:37
  5. 18' inch inovite rotors.
    By steve.o in forum Parts for sale
    Last Post: 11th June 2007, 21:44
