Thread: Slightly uneven idle when aircon is switched on?
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    Default Slightly uneven idle when aircon is switched on?
    Noticed this since I've had the car (before box!)
    Really nitpicking here I must add. As soon as I switch the aircon on, the idle becomes just slightly lumpy - and a little bit more likely to stall. It is certainly related, because as soon as a/c is switched off, it idles silky smooth again!
    Haven't stalled it yet, but I need to give it some extra revs sometimes to pull away.
    Any thoughts?
    totally normal.. the extra load imposed on the engine by the AC Compressor causes the revs to dip, what you cxan hear is the ECU raising the idle speed to compensate and then just fluctuating the idle to keep it around the correct idle speed.
    all perfectly normal
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    Sound, thanks
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Same on my two vectras. Nice and smooth with aircon off. Hunts with aircon on.
    Regular Member al21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    Vehicle : Vectra c
    Engine : 1.9 CDTI 150
    Year : 06
    Mileage : 193000
    it does it on mine too, poifectly normal
    Mileage : 000
    If you put all the lights on and the heated screen it would have the same effect, it is all the electrical drain causeing the alternator working hard that slow,s down the engine.
  1. A slightly different aircon question!
    By GoldenWonder in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 16:20
  2. Rough idle & aircon problem
    By Englishman in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2011, 06:23
  3. Hiss when aircon first switched on??
    By Rickiw in forum Diesel Engine related
    Last Post: 19th June 2011, 10:01
  4. 1.9 CDTI rough idle and uneven power
    By OilBurner in forum Engine & Drivetrain
    Last Post: 24th April 2007, 12:46
  5. FR 1443: Engine - Vibration at idle with switched on A\C system (Vec C)
    By Duncan in forum Heating, Ventilation & Air Conditioning (HVAC)
    Last Post: 25th June 2005, 16:48
