Thread: steering wheel swop over
    North West
    Default steering wheel swop over
    would this steering wheel fit my vauxhall vectra 20.DTI 2003 model.It has 4 spokes and looks the same
    Also do the european models have the word "AIRBAG" on the wheel in their language or is it in english ( i can't make out in the picture)
    If it fits,is it a a straight forward easy swop over..
    I only need the steering wheel badge to complete the change from vauxhall to Opel
    Don't mind paying either as i like job done right,you pay for what you get
    ch ears!!
    Tyneside
    If your steering wheel is a 4 spoke all you need to swap is the airbags, but there is 2 types of connectore depending on the year of your car and the year of car the steering wheel came off, it could be a 1pin or 2 pin connector.
    This might help a bit.
    http://forum.vectra-c.com/showthread.php?t=17112
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    standing on my head, squinting with binoculars I think it says "AIRBAG".
    I think duncan said the connectors at the back of the airbag changed in 2003 so i would e-mail the seller to ask. if you get the wrong one, thats it ,your wasted your cash.
    if you have the buttons on your steering wheel and a 4 spoke it will fit. just check the airbag connector(s).
    very easy job.
    1. find radio code (as you will need it)
    2. turn steering wheel to expose the two holes at the back (quarter turn to right)
    3. disconnect battery
    4. have cup of tea for 30mins or so
    5. find a small flat blade screwdriver to stick in the holes
    6. gently ease off airbag (being paranoid in case it goes bang)
    7. disconnect revelant connectors
    8. find a T50 TORX bit (found mine in halfrauds)
    9. remove bolt
    10. remove steering wheel ( mine came off easily)
    11. fit new steering wheel
    12 connect airbag
    13 reconnect battery
    14 code radio
    15 stand back and admire
    if just changing airbag steps 1 to 7 apply..........
    hope that helps.......
    North West
    Great info,i don't know if mine has 1 or 2 behind the airbag.But it won't matter cause i could just change the whole steering wheel as its identical apart from the badge.(AND THE SILVER BUTTON SURROUNDS ON MY 1)
    If the airbags do fit as you say i can just change that.
    I felt the screws behind the steering wheel and there is 1 opposite each other.
    many many thankses
    Jun 2007
    in a white box
    no, you need to check as the wire or wires coming out of the steering column.
    have a look tomorrow and you will see what we mean before you buy....
    and don't switch the ignition on with the airbag disconnected as you will get a warning light then its a visit to the dealers...
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by mark1319 View Post
    Quote Originally Posted by John35 View Post
    Yep, it changed MY 2003.5 from 1 plug to 2 plugs on the airbags - you gotta check what you have and what the new airbag has. If they're different then it's a no goer.
    Quote Originally Posted by Silver Vectra C View Post
    As John said, the connectors come out of the steering column so you have to know that you have the same number of plugs on your car as are in the new airbag.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    it is always 'airbag'
    Regular Member al21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    Vehicle : Vectra c
    Engine : 1.9 CDTI 150
    Year : 06
    Mileage : 192000
    bah , beat me to it lol, yes i says "airbag" on it
  1. For Sale: Sri facelift steering wheel c/w steering wheel controls
    By andy.l in forum Parts for sale
    Last Post: 3rd February 2013, 16:08
  2. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  3. Replies: 6
    Last Post: 13th March 2011, 10:47
  4. Wheel swop
    By soulman in forum Styling
    Last Post: 7th January 2011, 20:07
  5. wheel swop
    By Beavis in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2007, 01:27
