Results 1 to 2 of 2
Thread: Dragon Tuning box dpf compatible..???
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Default Dragon Tuning box dpf compatible..???
    Hi all, I was given a link to Dragon Performance's website and they are advertising that their DTE boxes work on vehicles fitted with DPF's??
    Not sure i'd trust a box on mine after reading various posts on here, I'm booking my new estate in for a remap as soon as i get it at either Regals or VXRPC as they seem to have dpf friendly remaps.
    http://www.dragonperformanceuk.com/s...at=1110&page=1
    Big-Pete
    DTE SYSTEMS TÜV Approved Electronic Diesel control units
    Dragon Performance is pleased to be the U.K's sole distributor for DTE SYSTEMS products.
    DTE SYSTEMS - German quality fuel enhancement technology.
    TÜV Approved products - 3 year Warranty and 30 day refund offer.
    DTE or Dragon? - We believe in choice - both systems will give the same performance, the DTE-Systems units have the German TUV approval which some German car owners prefer to have for added piece of mind. Function and usability is very similar between Dragon and DTE-Systems products.
    The new add-on DTE-Systems electronic diesel control units – intelligent diesel tuning technology for your vehicle
    Multi Ignition-Map technology that ensures maximum performance at minimal level
    Convenience in use only an add-on electronic control unit can provide and yet a driving performance so individual it as as though the original control unit software has been completely changed. Using multi ignition-map technology, this is exactly what the latest generation of add-on electronic control units are providing. Four to eight ignition maps are placed in the memory for the first time that then go into action according to your required driving performance. This means the optimal matching of all control parameters at every level of performance.
    This is possible through the use of high performance processors that facilitate the detailed real-time scanning of the ignition maps without influencing the internal protection functions.
    Optimal matching without the need for adjustment work - but how does it work?
    A further novelty is the ability of the systems to adapt to the individual characteristics of your vehicle. Over a short running-in period, the memory function detects the individual data for the differing fuel injection cycles. The information gained in this way provides the basis for the optimisation. The tolerances are then balanced and an optimal result is achieved with every vehicle without having to make any time consuming adjustments by hand.
    Fuel savings as a useful extra effect
    An enhanced ignition map leads to raised levels of efficiency, which in turn leads to reduced fuel consumption. The increase in torque facilitates a driving performance that requires fewer revs per minute, therefore significantly lowering levels of fuel consumption. According to driving performance, savings of fuel consumption of between 10% and 20% are possible, meaning that your tuning pays off very quickly
    Tuning also suitable for Diesel Particle Filter vehicles - DPF FAP etc
    A further advantage of the new add-on electronic control units with multi ignition-map technology is their compliance with vehicle emissions standards. Through enhanced burning in all areas of vehicle performance, the fuel is 100% efficiently used, with soot and smoke being things of the past. Because of this, unrestricted installation of the modules is also possible in vehicles with diesel particle filter engines.
    Regular Member Paul66's Avatar
    May 2007
    Basingstoke
    go for the remap, had mine done at Regal fantastic job.
  1. dragon 3.0 tuning box
    By phil bennett in forum Diesel Engine related
    Last Post: 7th June 2008, 20:13
  2. Dragon tuning box
    By mazz1 in forum Parts for sale
    Last Post: 24th January 2007, 11:52
  3. Dragon Tuning Box
    By Marky in forum Diesel Engine related
    Last Post: 17th June 2006, 12:27
